dp1504
Good day Fanatics
So a few months back I bought myself a 2014 f30 320i with the infamous N20 engine.
The car was really well taken care of and there is no mechanical issues at the moment or any iDrive warning notifications...
The car currently has about 132 000 km, and i would like to do the Timing chain replacement as recommended by most for peace of mind....
I have gotten a few quotes from a couple Service Providers, but one has recommended I do a couple additional replacements so i just wanted to check with other current/previous owners or knowledgeable members, what is their advice if it is necessary and what additional items i should consider changing as well?
List of additional items to be replaced:
I am in the Pretoria area, would also appreciate recommendation of mechanics(in Gauteng) that you have used or trust to be knowledgeable and honest to carry out the repair....
As anyone done the repair via their warranty plan, I do have one currently with a Third party , was the claim successful for this type of repair ?
Thank you very much in advance
Oil pump chain kit | |
Oil Pump Valve | |
Vacuum pump repair kit | |
Oil Filter Housing kit | |
Big End Bearings (Set) | |
Sump gasket | |
High pressure fuel pump – on engine | |
Adaptor | |
Balance shaft | |
Vanos central bolt | |
Crankshaft Sprocket |
