My 335i (Pre Mods)
kabal said:
looks awesome!!!
I thought the DCT would use more M3 style paddles, but they look more like the auto paddles? can you change up and down with either of them?
Yip, left and right do the same thing.
pull towards to gear up and push to gear down.
The M3 has the + and - on different stalks
Twinz
Forum - Support
Enigma, you must check out my mod where you can shift down left and upshift right as it should have come from the factory. No need to push the lever to shift gear. :thumbs:
kabal
can this mod be done so that you can push or pull left to shift down, and push or pull right to shift up?
I did actually read your write up on it Twinz, its a pity the M3 style paddles dont fit exactly but i like how you modded the stock ones to work the same way.
Im way too paranoid to start changing wiring though!
