andrewza
Hey peeps,
The second gear in my manual box (GS6-45BZ I think?) in my E82 135i is missbehaving but I can't seem to pin it down exactly. But they only started happening after a recent clutch-swap (OEM clutch kit, thrust bearing, new pivot pin+spring.
Symptoms:
Something else? 🙏
Symptoms:
- Sometimes, if shifting down from 3rd to 2nd with heel-toe, say third at 3,000 RPM, after shifting into 2nd the gear "pops-out" with some relatively light grinding sound, as if you tried to shift without depressing the clutch pedal.
- Occasionally, even though 2nd engages and at low speed, the gear does a similar pop-out, and grinds in a similar way.
- The two symptoms above seem to be related to heat, if it's colder it apparently happens less, but not always, the 3rd to 2nd downshift pop-out has happened while warm after a decent trip of ~20-30 kms.
Something else? 🙏
