Thanks man, so i assume the stage 2 pump is only needed when you go bigger turbos or single turbo.
B bmw335ie90 Member Sep 18, 2017 #21 Thanks man, so i assume the stage 2 pump is only needed when you go bigger turbos or single turbo.
Psypher13 Active member Sep 18, 2017 #22 bmw335ie90 said: Thanks man, so i assume the stage 2 pump is only needed when you go bigger turbos or single turbo. Click to expand... Hey Bro Yeah Stage 1 Is more than enough till you really need more with a bigger better setip over stock
B bmw335ie90 Member Sep 18, 2017 #23 Thanks allot, and is fuel it the best option? or not for a stage one lpfp.
B bmw335ie90 Member Sep 18, 2017 #25 I meant fuel it like the brand name. Walbro is the other brand that comes to mind.
Psypher13 Active member Sep 18, 2017 #26 Oh yeah - you can use the walbrow Pumps as well but that will need modification i have use in the past and it works well
B bmw335ie90 Member Sep 18, 2017 #27 Last question what brand did you use to hit 344wkw on the stock turbos. Thanks for your help :=):
Psypher13 Active member Sep 18, 2017 #28 Fuel-it Stage 1 buddy I only went stage 2 when i went Bigger turbos
