///Maniac
So I recently read the fault codes on my 2006 330i. This is what comes up:
DME:
29F4 Catalytic converter conversion, bank 1
29F5 Catalytic converter conversion, bank 2
2AAC Variable intake system 2, self-diagnosis
2A87 Variable camshaft timing (VANOS) exhaust, mechanism
MRS:
93A9 Belt tensioner, driver
93AD Side airbag, front right
Now the car has been decatted so I accept that the first 2 codes will be there. My question is with regards to the Vanos and DISA faults. I did try and clean out the solenoids but it didn't make any difference so I guess I will have to replace the solenoid. I have read that this could also be causing the error code for the DISA. Is this plausible? Any advice on that code will be appreciated.
Next to tackle the airbag light. The airbag light recently came on. i have tried resetting this with INPA but it does nothing. The light remains on. How do I get rid of this? it is annoying to have that light on and the warning tone everytime I start and switch off the car.
DME:
MRS:
