DarrylvanNiekerk
Please can someone help shed some light on an issue that has been plaguing my car for the last few years.
I had the standard exhaust removed including manifold and a sports exhaust installed. Directly thereafter, and not related to the current issue, the car started smoking. Catalytic converters were masking a valve stem guide issue that the previous owner caused by meddling where they shouldn't have. That was solved.
Then I started to notice the car cutting power or hesitating around a right hand corner every now and then. This grew to cutting power sporadically and eventually being completely retarded at low engine revs, sometimes up to 6500.
I sent my car to a mechanic I trust who consulted various BMW specialists and had it on many launches. We went through changing VANOS, coil packs, injectors and various other items - thankfully he never got brand new but swapped from vehicles that worked to confirm whether this made a difference to no avail.
There have been a variety of fault codes from Valvetronic eccentric shaft sensor (which was replaced, this time at cost), O2 sensors ageing, heating, mixed up, misfire on various cylinders and plausibilization exhaust gas oxygen sensor.
Spark plugs have been replaced many times, injectors cleaned, valvetronic motors cleaned, engine flushed, timing checked and rechecked. Every time we think the problem is sorted it flares up again after a few days. Ever so slightly at first but then to a point where it becomes undriveable.
There are very few options now except to try and reinstall an exhaust manifold with O2 sensors and hope that solves the problem. I used to love the car so much but it has become such a frustration, I haven't been able to drive it for the last 3 months as it is currently on firing on 3 cylinders.
Thank you.
Thank you.
