E90 - 283d Vanos - Adaption stop
Tha_ruler_05
Hi,
Do you think it is faulty vanos solenoids causing the car to lose power when going over 3000rpm. Car drives fine until you hit 3000rpm then seems like there is not lift and then when pulling away cars seems to be in limp mode. once I turn the car off and start it then it drives fine again until you go over 3000rpm.
Kyle
283d is exhaust side IIRC... Have you tried swopping the solenoids around to see if the error moves to intake? Also try cleaning them as well.
