My service book doesnt even show my car! only 316I - 3.0L M3..
How does the South African-spec S50 B32 engine differ from that of the European-spec version?
Due to low-octane fuel requirements, the S50 B32 motors produced for South Africa utilize different pistons which result in a reduced compression ratio of 10.5:1. These engines produce 310 hp (DIN) at 7,400 rpm and 251 lb/ft of torque at 3,250 rpm.
How does the South African-produced E36 M3 sedan differ from the European-spec model?
The South African-spec E36 M3 sedans are essentially identical to the European-spec version but utilize a low-compression version of the S50 B32 engine designed for low-octane South African fuel that produces slightly less power and torque. In addition, SA-spec E36 M3 sedans were offered in a slightly different selection of exterior colors and were equipped with a large array of standard equipment, including: extended Nappa leather upholstery, forged M Double Spoke alloy wheels, M3 GT-style front "splitters", power sunroof, power front seats, rear sunshade, automatic climate control, cruise control and the on-board computer.
What changes were made to the European-spec E36 M3 3.2 during its producton?
The only major mechanical change during the production of the Euro-spec E36 M3 3.2 was the addition of the Sequential M Gearbox (SMG) option in 1997. In addition to SMG, various minor upgrades were introduced before production ended in late 1999 including:
-Restyled grille and side marker turn signals (9/96 production)
-Sculpted side valance panels (as already fitted to M3 coupe and M3 convertible) standard on M3 sedan (9/96 production)
-Three-spoke M steering wheel available (9/96 production)
-Byzanz metallic available (9/96-8/97 production, sedan only)
-Side impact airbags available on sedans (1/97 production)
-Side impact airbags available on coupes and convertibles (9/97 production)
-Illumination added to M shift knob (9/97 production)
-Imola Red (405) paint available (3/98 production)
-Titanium Silver metallic (354) available in place of Arctic Silver metallic (309) (3/98 production)
-Fern Green metallic (386) available in place of Boston Green metallic (275) (3/98 production)
How is the North American 3.2-liter M3 engine (S52) different from the 3.0-liter (S50 B30 USA)?
Unlke the Euro-spec S50 B32, the S52 powerplant is an evolution of the standard production M52 engine. However, it incorporates the following changes over its S50 B30 USA predecessor:
-Increased bore to 86.4mm (from 86.0mm) and increased stroke to 89.6mm (from 85.8mm) for a total displacement of 3,152cc (from 2,990cc)
-More finely balanced camshafts
-Valve lifters, springs and spring seats with reduced mass
-Revised intake and exhaust systems
-OBD II (On-Board Diagnostics, version II) compliance
-Horsepower unchanged at 240 hp (SAE) at 6,000 rpm
-Torque increased to 236 lb/ft at 3,800 rpm (up from 225 lb/ft at 4,250 rpm)
NOTE: E36 M3s equipped with the ZF five-speed automatic transmission are rated at 225 lb/ft of torque at 3,800rpm.
How many of each version were produced?
ECE coupe (LHD): 6,117 produced from 09/95 through 12/98
ECE coupe (RHD): 2,845 produced from 01/96 through 12/98
NA coupe (LHD): 11,793 produced from 03/96 through 04/99
ECE convertible (LHD): 1,763 produced from 02/96 through 08/99
ECE convertible (RHD): 2,107 produced from 02/96 through 07/99
USA convertible manual (LHD): 2,252 produced from 03/98 through 08/99
USA convertible automatic (LHD): 4,017 produced from 03/98 through 08/99
ECE sedan (LHD): 1,296 produced from 11/95 through 01/98
ECE sedan (RHD): 694 produced from 01/96 through 12/97
NA sedan manual (LHD): 4,574 produced from 09/96 through 05/98
USA sedan automatic (LHD): 4,036 produced from 09/96 through 05/98
SA sedan (RHD): 168 produced from Complete Knock Down (CKD) kits from 11/96 through 04/97, 532 produced as complete cars from 04/97 through 10/98
