BMW Aftermarket warranty - High mileage f30 320D
ashlinm
Good morning fanatics
Have a question and would like to get your thoughts and opinions. On my 2016 BMW 320D, I had a aftermarket warranty with Bidvest, it has just expired (in the two years off ownership I did not use it 😅).
My mileage is around 205k and was just wondering if I should consider taking out another extended warranty? If so, any suggestions for higher mileage options.
Also wondering if it would be worth taking out considering most cover is quite less due to age/mileage.
Thanks again!
///M Individual
Hi bud
Been there done that never got to claim because these cars are so damn reliable! :cautious::D
Personally I don't think its worth it.
Rather spend on preventative maintenance items. Not sure what's been done already but stuff like the vibration damper, coolant flange etc.
Also a downpipe and remap is in order!
momo1
Hi bud
my thoughts too
PsyCLown
Whether an aftermarket warranty is worth while is entirely up to you. Your car and you're the one taking the risk and spending the money.
I have one for my 540i and am very glad I do as I have just had a large claim approved and covered by my warranty. While the B58 is generally considered reliable, it does require more money to be spent on maintenance than a 20d typically does.
The warranty I have is a lump sum amount and not a set amount per component / category and covers upto 450 000km, I do not believe the payout is reduced based on mileage / year - it just needs to be within their mileage and age requirement.
ashlinm
Hi bud
Hi bud
Thank you for the response, these cars are amazing 😅
I will look at performing preventative maintenance items you mentioned, I have only done ZF gearbox oil change, routine oil services and both front and rear brakes.
Was considering doing DP soon and remapping. Still looking for suggestions in KZN north coast and surrounding areas.
ashlinm
Thanks for your input @PsyCLown. If you don't mind me asking who is your aftermarket warranty with?
AshG108
Hey bud,
Great advice from the guys above. I have had a few of these 20ds now and also in the family and honestly, into high mileage they are still very decent however they require wear and tear items which would cost more as they age, right?
So if you did the main items now then plan for these normal things going forward and then also to revisit things like the Vibration dampener later on, the gearbox service or maintenance too...suspension parts as well.
Salt
Here is my view on aftermarket warranties. I have used this on multiple vehicles for over 10 years. I have used multiple service providers. From my experience, the only way you can get unlimited cover is when you take out the extended warranty BEFORE the manufacturers original warranty expires - then you can usually get unlimited cover (no sub limits) for 2 years/unlimited kms. Anything after the manufacturers original warranty has run out, the cover is based on vehicle age/mileage and sub limits will apply - R50k engine, R40k transmission etc. for example. You also cannot take out the same cover again when it expires - the vehicle age/mileage will then be used to determine the next cover applicable. You got both monthly payment and once off payment options. I've always gone for once off...although monthly has the advantage that should you find service poor or unfair, you have some leverage - T's&C's dependent.
Important lesson learnt by myself recently...I extended the 140's motorplan with BMW for one year, I then wanted to take out an extended warranty thinking I can get the unlimited cover option...however their view was that the manufacturers original warranty ran out when the original motorplan ended after 5 years and thus I only qualified for the next option which had sub limits - which I did take and have successfully used since. But knowing what I know now, I would rather have taken out the unlimited cover warranty at the end of the 5 year motorplan.
Hope this helps.
ashlinm
Hope this helps.
Thanks for the input @Salt very informative.
PsyCLown
Hope this helps.
Majority of my experience with aftermarket warranties is along these lines:
Sub limits, age and mileage of vehicle puts you into different categories and as the mileage and age increases the sub limits shrinks until it no longer makes sense to have the warranty.
The Innovation Group Motormend warranty which I have is a little different.
No sub limits, just an overall pot of funds. With a single claim I have been able to use 2/3 of that overall sum.
My friend has the same on his Audi S3 and his Amarok and it has paid out on both vehicles with little fuss. The one thing they did not cover was to rethread a bolt hole on his S3 sub assembly. They stated that was not covered by the warranty but covered some suspension parts and some others parts I cannot recall and have recently approved a claim for a new VW alternator & labour on his Amarok.
Larger or more complex claims it seems they send out an assessor, lower cost or more straight forward claims they just approve.
I guess the downside with this warranty is that there is a limit to how much they will pay out overall. You can end up in a situation where the remaining amount is not enough to fully cover a claim and you're left paying the difference out of pocket... Although based on the sub limits on a typical warranty, you generally need to pay in most of the time anyways.
So far, for me at least, this pot of funds system on this aftermarket warranty is working quite well and has paid out more than I have paid for the warranty itself.
Salt
I like this concept. First prize for me however remains taking out the unlimited cover/unlimited km's/2 years warranty BEFORE manufacturer's warranty expires - however important to note there is still a clause of one component per claim at a time and can't claim for the same component within a x amount of months (usually 6 months) - however no limit to claims over the 2 year period - so they could theoretically replace an engine twice over 24 months - although that would probably take some serious convicing lol. I think though that now that I know about your option, it's definitely the one I would go for in the case of being out of manufacturer's warranty and then looking for cover - like I was now recently.
Curious though if the same clause about one component per claim applies in your case? It did in my claim for the coolant system last year - 5 pipes, aux water pump, intake manifold, oil filter housing - they only approved payment for one of those components - so we went with the intake manifold (the most expensive one) - BMW then assisted with goodwill for the rest and I paid in the difference (which was a considerable amount still).
PsyCLown
I agree 100%, first prize is the unlimited cover warranty. The 1 component per claim can be a challenge if multiple issues happen at once.
With the warranty I have, you can claim on multiple components at once. Most workshops would offer at least a 6 month warranty so I can understand why they might not want to cover a claim for that same component within that period as the workshop should be the one to cover it.
