Back in the family ... fourth time round :)
Scubadude
Hi all!
Let me introduce myself quickly. I'm Francois de Villiers, as of today a fourth time 3-series owner. My previous cars were a 1991 E30 325i MEX, 1995 E36 325i M and a 1998 E36 328i Exec. All three gave wonderful service, eventually sold at 300 000, 250 000 and 200 000 km respectively. The 1991 car was particularly impressive because I was young, had it a little modified and drove as hard as I could, always! Only started using a little oil between services from around 250 000km.
I'll be starting a new job on the other side of Jhb next month and will be travelling around 200km/day for the first 6 months. Therefore I went shopping for a reliable, comfortable and low mileage fuel saver that wont loose a heck of a lot of value by adding 50 or 60 000 k's in the next year.
I eventually decided on a 2002 E46 320D Auto with 120 000km on the clock. It may be my 4th 3 series, but my first oil burner and first automatic.
The car is in super nick (boot carpet not worn, full set of tools, no accident damage) but has a somewhat less than full service history. I plotted the service records and its a perfect straight line of 12000km per year, so I am comfortable it is a one owner car. Dave Robinson checked it out and gave it the thumbs up and it one hellavu nice drive. It has just been serviced includin glower control arm bushed, has 5 new tyres, and the purchase price included license, registration, a nice polish and a full tank of diesel :)
Probably overpaid a little ... R 88 000 which is around R 11 000 above retail. But then again, what else can you buy for R 88 000?
So now that I'm back in the family, a couple of introductory q's:
- tyre life on these cars ... I know its related to tyre type and usage patterns, but what could I resaonably expect based on mainly highway travel at legal speeds?
- with the above usage profile ... 6.5l/100 achievable?
- suggestions for good independent BMW workshop around Pretoria / East Rand / the South?
- things I have to check out immendiately? EGR, crank breather, what else should I not leave to the next service?
That's it for now ... hell it's good to be back!
Francois
Oh yes ... one more.
Is the 2002 model the one with the more robust swirl flaps and electronic turbo, or am I mixing my threads?
One more ... is the 2002 model fitted with the more robust swirl flaps and electronic turbo actuator?
Scubadude
Thanks for the welcome guys!
Some crude pics below ... will take some more and post later.
Two more questions:
- Does the 2002 have the newer type inlet manifold with the more robust swirl flaps
- I never checked but the ad said "radio/tape" and that's what I have. No CD and certainly no USB. What are my options? FM modulator? Replace aftermarket radio? Shop around for shuttle from wrecked car?
Scubadude
Did my first return trip home and back to work and I'm giddy with excitement ... set the cruise control at 120 and came in at 6.3 l/100km.
Now that I think about it ... only 1 better than I get on the V6 Pajero ... but a very critical 1 ... the 1 in front of the 6. The pajero does around 16.3 l/100 km. At a 10l/100km difference and 60 000 km p.a. that is a saving of R 72 000 a year in fuel alone !!! :joy: Must just remember to park some of the savings for the turbo rainy day fund ...
Dopi
Yip, yours got the swirl flaps, best to remove them as quickly as posible, is it still on the original turbo?
Scubadude
Original turbo? Guess so ... no record of major repairs.
EGR I will clean next weekend and decat at some stage. Swirls flaps can simply be removed, right? And the check for crank case breather in oil in the turbo?
XMAX
Congrats on a good car.
She seems quite neat and the info seems good.
you should also do some of the other preventive maintenance things like change the Expansion tank, and water pump. Removing Swirl Flaps, EGR Delete, and a decat are definitely a good idea.
Also, seeing as you are new to tractors, please follow start up and cool down procedures to prolong the lifespan of your car. This involves driving the car slow, and out of boost until it reaches optimal operating temperature, and allowing the car to idle for a few minutes before switching off. what I find also works is driving the car out of boost (slow) for the last few kms of the trip and idle for a minute or so before switching off.... Doing this may ensure a longer lifespan of your turbo...
You should also consider two options... Obtain a Mechanical Warranty or religiously put away money monthly to spend on repairs. Im not trying to scare you, but some of the repair costs on the diesels are extreme.
On the mechanical warranty side, I would advise SA Warranties.... BUT all aftermarket warranties have coverage limits. so they may only cover a portion of the repair bill... Best to also have a few bucks aside.
Best advice is to fix a problem immediately as the bills can add up and shock you into submission.
In terms of repairs... Tunetech are amongst the best there are. Even better than the agents, yet theyre sooo much cheaper than the agents (though not super cheap)...
