I wanted to try it out and see if it's any good. Durban area Let me know. Thanks
MightyM New member Sep 30, 2025 #1 I wanted to try it out and see if it's any good. Durban area Let me know. Thanks
///M Individual Well-known member Sep 30, 2025 #2 Is the car still under plan? If not consider an ecu remap instead.
MightyM New member Oct 3, 2025 #3 The cars a 2015 model with 97k km on it. If the remap allows me to toggle between the standard setting and a upgraded setting... Then I would look at it. Any recommendations in durban?
MightyM New member Oct 3, 2025 #4 ///M Individual said: Is the car still under plan? If not consider an ecu remap instead. Click to expand... The cars a 2015 model with 97k km on it. If the remap allows me to toggle between the standard setting and a upgraded setting... Then I would look at it. Any recommendations in durban?
TurboLlew Honorary ///Member Oct 3, 2025 #5 Speak to @Xcede Performance first. there may be an option for you that works for a one-and-done type map as well.
msm Well-known member Oct 3, 2025 #6 MightyM said: The cars a 2015 model with 97k km on it. If the remap allows me to toggle between the standard setting and a upgraded setting... Then I would look at it. Any recommendations in durban? Click to expand... +1 for Xcede 10 year old diesel - go do it properly with some hardware and a proper tune that also gets rid of the (potentially clogged) emissions stuff at the same time - EGR, DPF, etc. Do it on the cheap and you'll end up paying more in other ways...
msm Well-known member Oct 3, 2025 #7 MightyM said: If the remap allows me to toggle between the standard setting and a upgraded setting... Then I would look at it. Click to expand... I'm 90% sure that the guys who do tuning can use your current ECO/Comfort/Sport settings for this
MightyM New member Oct 3, 2025 #8 Thanks for the input all. Ill give the remap guys a call and see what they can do. Appreciate it gents.
