mathias
AshG108 said:mathias said:individj said:I cant comment technically but would imagine the 30D & 40D are very close...think its intake and turbo....M50D i think will have much more difference.
there was a swopped 1 series in Speed & Sound...140D...swopped from a 6 series i think.
O wow, thanks for bringing this to my attention it was a great read... the 140d is an absolute beast but has a lot more done to it over and above the engine swop.
Here is the link for those of you which haven't read it https://www.speedandsound.co.za/smoke-factory-a-retrofitters-dream/
billionairebum said:This is the correct answer. It is not a cheap exercise, but a few guys have done it on their 30d and achieve around 330kw and 800nm+. RK and Madness have cars that have done this.tman said:single larger turbo on a 3.0d is probably the most economical path. Has been done, and from what I hear power figures are good
Thanks Gents, have been following Madness for awhile so I'm aware of the bigger single turbo option but this comes with other issues, was hoping for a "simpler" OEM option...
My thinking is that BMW would have done their research and opted for the various turbo options for a reason as I will be using the car as a everyday drive, then there is the fact that these OEM parts are readily available both new and used.
Will do some further research on the OEM 40d/50d parts otherwise the bigger single turbo option will definitely be a feasible option.
You mention some words which spark a very eay answer for you "simpler" "Other Issues" "Daily drive"
Go drive the 30d that was done by Sherwin, and then decide from there how far you want to stretch into...you want a simple and reliable daily drive with power to punch when you need, a well boosted and maintained 30d is not bad at all.
Thanks Ash, was there ever a thread made for Sherwin's 30d? would love to give it a read. Ive only come across the 30d which was tuned by Madness
I realize now that this "conversion" wouldnt be very simple at all! As most of the external components would need to be exchanged, was hoping it would be as simple as swoping the turbos and giving it a flash but based on all the very helpful answers above this doesn't sound feasible at all, I could potentially replace components as/ if they fail with 50d components one at a time but this would probably take forever as they don't fail easily.
So yes DP, DPF & ERG off with stage 2 tune sounds like the way to go. Might add Meth injection at a later stage if cooling becomes an issue with the stock intercooler.
