Things to look out for when buying 3 Series
mikesickle1
Hi Anyone in CT who knows where to buy a set of fan clutch tools for removal from waterpump? 3l M54 motor. Thanks
Sent from my LG-H870 using Tapatalk
Navigator_E90
Make sure the ECU box's water drain system is open and working... Had ECU water damage on my 320d and resulted in a crap load of money to have it fixed,
Its a horrible design recommend you strip and remove the ECU to make sure the drain is open, not just in the ECU box but also the drain in the steel part of the chassis where the ECU box fits in
donovanc
I would recommend take the vehicle to agents for a airbag check.
Allt of these old E46 haven't seen the Agents from the time the motor plans ended.
My 2004, E46, 325ci, has a old recall campaign , on the two of the airbags I think it was.
