My Classics..
AshG108
What the hell...
Yes it is not BMW.. But old school fords did have their days and still do... These are very rare!! Well done :blowheart::blowheart::blowheart:
I don't mind having a Mk1 Escourt, Fordv8 Capri & XLE big 6 in my garage :blowheart:
That makes the 2 of us...My exact old-school garage that I want as well!
warrenk
Hi Members,
Here are some updated photo's of the Sport.
I entered the car in the George Old Car Show that took place on 11 Feb 2023.
The center lock adaptors for the Hayashi wheels had to be refinished as I did not oil them up when I put the wheels into storage. The wheels went back onto the car with a new set of tyres and the car went back to Bouchers that did the paintwork to get ceramic coated.
It was a 626km round trip and the car used 54L of fuel which equates to 11.6km/L, I was surprised at the consumption as I was expecting around 9 to 10km\L. We picked up one stone chip along the way but it's one of those things, I need to use the car, it was not built to be a garage queen.
There were some quality cars at the GOCS but the high light of the trip for me was the drive to George and back.
individj
damnit i missed the show...your car is incredible...truly special...what a mission to drive it down to George...a dream that i will realise next year...
individj
i want to steal your wheels and put them on my Datto....theres a beautiful set of Enkeis 4 spokes floating around too.
MOE 000 GP
Well I'm in the process of restoring this 1959 karmann ghia of my late grandfather... Car has only 5000km genuine Kms ..he bought it brand new for R875 lol so it works just it was standing for more then 40 years in the storage shed .. And it's a guzzler on fuel
Gordvisr
you must somewhere start a thread on this.
Gordvisr
Hi Members,
looking really good
warrenk
Hi Members,
Yearly update.
I attended the GOCS 2024 in Feb.
Everything leading up to the car show was just one big PITA. But, in the end, I made it, Drove to George and back to PE without any major issues. I took the R102 from just after the Van Stadens bridge and got back onto the N2 by Eerste Rivier, it was my first time driving that road and I have to say, I'll take it every time from now on.
Below is one pic from the GOCS and the other 3 photos someone else took at an EPVCC meet 2 weeks later. The Sport next to mine is painted in BMW Brilliant Red whereas my car is the original Ford Venetian Red.
Fordkoppie
Hi Members,
Yearly update.
I saw this car at the GOCS..... It was parked almost in the corner of the field.
AMAZING condition!!! And the attention to detail is next level. Well done!
Pity I couldnt speak to you, because I wouldnt be able to identify the person attached to the car. lol
///M Individual
Hi Members,
Yearly update.
Absolute beauty bud! :love:
warrenk
After a long silence, it’s time for an update.
After GOCS2024, I returned home and pulled the struts out of the car. With us using all sorts of methods to try to get the centre-lock wheels off, it seems we damaged the seals on the front struts. The front coils were also making a noise, and on investigation we found that the springs were turning in the cups. This was because I hadn’t refitted the sleeves/hose sections around the ends of the springs when I reassembled the car in 2019/2020. I don’t know what changed, but because of the leaking dampers and the noisy springs, I decided to lift the car 20mm all round and change from 175/50R13 to 195/55R13 tyres. Our roads are getting worse by the day, and the bigger tyre gives me a little more cushion.
I had my spare set of Superlites refurbished, along with a set of Compomotive MS wheels. Both are 13x7, but the Superlite is a -7 offset and the Compomotive is a -6 offset. Once I had the suspension back together and the car on the ground, it became clear that one of the two manufacturers can’t measure - the wheels were touching the arches with the bigger rubber.
I opted to fit the MS wheels, which were only on for a very short time before a wheel I’d been after for a very long time became available: the Compomotive CXN in 13x7. These wheels have never been repainted or repaired. I got the CXNs on and did some kilometres around town to make sure all would be in order for GOCS2025. During this time it became apparent that the new Gabriel dampers I fitted are utter rubbish. They’ll be staying in the car for now, though, as I’m busy finishing off other projects and need to route the funds in other directions.
On the day I left for GOCS2025, I made it as far as Jeffreys Bay. After watching the temperature gauge for about 20km. It was a little higher than usual, and when I gave it a bit on a long hill, I saw it climbing. So I did the responsible thing, turned around, went home, parked the car and left for George in the Hilux.
When I got back from George, I pulled the radiator and found little white crystal-like balls in it. I then removed the thermostat, refitted the radiator and flushed the system twice with oxalic acid. I’ll share a photo of what the inside of the cylinder head looked like after two one-hour idle sessions with the oxalic acid in. I then flushed everything properly and took the radiator in to have the tanks pulled, the core cleaned and everything put back together again. At the same time, I fitted a carb kit I got from Clive Wilmot and replaced the rubber hoses.
On GOCS2026, the car ran very well there and back, but a split fuel line meant a quick roadside repair before we were on our way again. It looks like the rubber hose you get nowadays needs to be inspected and replaced at least every six months. The hose that split was between the fuel pump and the carb, and it was only 9 or 10 months old, though I’m not sure how many years it had been on the shelf at the shop.
Anyway, enough babbling. Here are some pics.
Benji
You have more spare wheels than spare underpants! Car is looking clean!
Ive noticed the same thing with fuel lines, it is almost worth it to go get an OEM fuel line from BMW - at around R300 a metre! Not sure where else one can get proper fuel line in SA?
