125i E82 Running rich after decat and tune
Hi Gents/Ladies,
I recently sent my 2011 125i N52 for decat and tune. Power feels awesome and throttle is very responsive.
When I took reading before the tune all values were normal. What I'm seeing now is the trims for bank 1 and 2 consistently being negative, ie. the ECU is trying to remove fuel. These values fluctuate but sometimes hit their limit. During these times I experience hesitation, usually high gear low rpm under load on the highway, but only when not at operating temp. Once at temp there are no issues. Similarly with the engine idle, slight fluctuations but then clears.
Anybody have experience in tuning their N52s? I would like to know how it went. I've also attached my sensor readings for a cold start run.
  • 2026-11-25_07-01-23.csv
Hi Gents/Ladies,
Howsit bud,
Who did the tune and decat for you?
Ideally, your tuner should be able to review these logs and understand or elaborate on why this is happening.
Was the car in good health before you did these mods?
@Xcede Performance - these guys done a good few of these and should be able to add some info if possible however the original tuner has the IP to understand and troubleshoot.
Howsit bud,
NFS Tuning in Edenvale. Car is in mint condition, 130000kms. Not much of an explanation other than more fuel = more power lol. He suggests changing the plugs as they may be overdue, but still doesn't explain the large discrepancies between the before and after results.
Nah,
Don't go to changing things as soon as it goes wrong.
Rather get diagnostics run and take it from there.
I don't know that tuning shop at all, however Tuning on a petrol engine is not only More fuel = more power.
There is Air - to - Fuel Ratios etc
Xcede Performance
Was the car data logged before and after tune? Before and after dyno graphs? Wide band measure fueling?
We've done countless number of these over the years and honestly cannot recall having any with these issues.
