320d
Normally if there is a oil residue in the exhaust from the turbo it takes a while to burn out. if it doesn't come from a different source.
So drove about 10 km, she is still smoking, removed plugs, no sign of oil burning. The misfire i had on cylinder #3, is now gone. So will drive it some more and see what she does. Have not pushed her yet bit can hear the spooling of the turbo's a bit louder than with the XM cores . Glad i did the swop, clearly had damage on the one turbo. Time will tell.
Gordvisr
It makes sense, did go through this rodeo before and smoke was gone , it did not take a while. I gambled doing the snails first, i was lucky to find diffrent damage to one of them and it solved a misfire issue that have been hunted for quite some time now.
individj
solving a misfire issue is a very satisfying situation.
320d
miss
The turbo solved a missfire issue?
Gordvisr
Took the car on a 200km drive after all fluids changed in engine bay, after the swop, it feels like we lost a bit on low down torque( turbo lag). Higher up there is a bit more punch than before. She does also have a bigger bark than before, the noises voming from the exhaust is something else.
Bugger
So, just something to consider, may or may not be worthwhile investigating unless you've done it already. Has that engine ever had a carbon clean? The engine is direct injection, so as per normal for any direct injection engine, carbon build up is a thing. And you've got well earned and used mileage. I remember on my RS4 after I did a carbon clean it was like a new car, no smoking, lots of power, it made a massive difference.
320d
We need video proof of this :D
Yeah I would have started there, crazy misfire issues have been caused by carbon buildup in the VAG stable and I'm assuming it would be the same for the bm, if so invest in a water/meth injection system if you intend keeping the car
