Small update
Since the Engine rebuild, aside from the Popped Radiator, The car has been pretty reliable.
After putting about 1000km on the engine, Oil was drained And new Motul 8100 X-cess 5w40 used.
And the car drove perfectly since.
December 2025 was ALMOST a repeat of 2024 thanks to 2 mistakes i made.
Listing Mistakes so i dont make it again and so others can learn from it too.
Mistake 1:
- On fresh rebuild, I used 5w40 Motul oil instead of a run-in oil
- should have used a 10w40 to help with Bearings/Rings to "seat"
Mistake 2:
- Supposed to do a few oil changes to clear oil/Engine of seating materials.
- I only did 1 oil change at 1000km.
So Started Hearing some "noises" from engine that kind of Put me on edge.
Like a grinding noise but got louder as you drive.
Naturally i was thinking Worst case scenario and i pulled the oil filter.
Saw no material in the ribs of concern so i figured ok i should be fine
As soon as the Pan the filter was in hit the light, I nearly had a Damn Heart attack
This is what i saw ( Excuse the poor quailty pics ) microscopic GLitter in Oil. Only seen under sunlight.
Cannot feel on fingers.
Drained the oil and there are few tiny particles in the oil
Needless to say, I drained the oil immediatly and Changed it with new oil filter.
But my "Noise" was still there.
After i calmed down abit, made a few phone calls and everyone telling me to relax and that for 9000km i been driving with Oil that had Seating material in it and thats why it looks sparkly.
And Contacted Baby Jakes and he came round to check it and Said its normal for new engine and he seen MUCH worse.
He also mentioned, Use of Some Assemble lube will also make Oil appear sparkly.
Also advised to change oil and Send it. Advised to change the oil again end of Jan and See what it looks like. ( it should obviously show a decline) ... I HOPE!!!!
After that and i was able to think clearly, I pulled the belts and started the car and that "Noise" was gone...
GOD DAMN TENSIONER PULLEY!!!! lol. (Topran Crap that only lasted 2years according to my invoices)
Replaced Both the Idler and Tensioner pullies
Once all belts on, the "Noise" is now gone.
A scare and a half but im glad it made me check the oil filter. as i had another 1000km to go before i was going to change the oil again.
Lessons learnt:
Use run un oil on start up. (Was told 10w40)
Drain after 15min and replace with Fresh oil.
Run for 1000km and then drain and Put in 5w40
then run to 3000km and Drain and Put in 5w40.
Right now, She runs strong. no noises that concern me
no Rumbles when driving beside a wall ( Beleive me im checking EVERYDAY. lol )
for those who rebuilt these engines or the likes, is this normal? and do you think i will be ok?
I cannot wait for End of Jan as im itching to drain this oil again. LMAO!
