General.Massacre
Hi @Peter@AEW i was astounded at the amount of wear for the apparent mileage the motor supposedly done in the time.How is it that the bearings took such heavy wear?
Was he able to explain possible reasons?
The oil pump does look a little worse for wear but not so much as to cause bearing wear?
Budler said its highly possible that the crank was initially just refitted without engineering done as they most probably looked at it and said its fine, thus fitting it with new bearings, and as Llew said, possible they fitted incorrect bearing colours/sizes, coupled with that and the possible bad crank to start with, would have eaten the bearings. but no matter what is said, this is all speculation at best.
8 months so far? WTF, mind sharing which builder its been at for this time frame? i mean granted im no expert at all, it would probably take me far longer to try and build this engine anyways, but id assume (i mean, hope), that a workshop that accepts a car like the M5, M6 or similar would be confident in their work doing it correctly. if not, why not just state this is not something you're comfortable with, and recommend others, i would respect a shop like that so much more.3-4 weeks is record time compared to what you face from other places on ordinary cars. I have personal stories on this...
Unfortunately there is this disease with workshops that see any car and assume its the same... and the tropes on the groups of M motors not being special and being just the same as N55/N63 etc... give them confidence. I shared this story and thread with someone building an F10 at one of these places that has taken 8 months so far... It is now apparently going to MPH who has actually done a few.
The money involved seems high but you're probably good to go for another 100000+ after this. It isn't THAT bad if you consider that you cannot build eg: a Subaru 400-500kw capable motor for R150K... Certainly not a V8TT/V12TT merc motor - Those very fast RS3s & TTs have eye-watering amounts of money poured into them if you talk to one of the owners (2-3x your build cost and multiple times when they break) - you will likely not be able to build a Lamborghini motor south of R700K (one of the club guys had the misfortune of having a V10 go at 75000km... if the E60 owners think BMW did something wrong for their V10s to last 'only' 100000km before needing maintenance then they should look at the 'next' up exotic V10 costs LOL)
It's bad in absolute terms - but not that bad...
@Peter@AEW My laymans guess is they also used the incorrect sized/colour coded bearings on that crank when rebuilding (over and above the various other strange things they did during assembly) - either because they were used to N-series colour references or they just didn't know. I guess is the builder would come with different stories.
I am confident int he fact that Budler, as i stated previously, is the best place the car can be, judging by their experience and exposure to the brand and platform. so my spirits are high in this regard.
I feel sorry for that gent with the Lamborghini that had his motor let go, hoping he has warranty, unlike me.
