Don't worry. They'll come. Hang in there.Booooeet! First order of business is a short video! Even if its just a start up and a walk around the car.
I had my shims done at a BMW Mech here in JHB. Reason was, shims take about 2 weeks to arrive from Germany. So you need to measure all your clearances, work out what shims you need, order them, wait, install and remeasure, praying that you measured correctly the first time...I took it to someone who had shims in his workshop, so it was a quick jobHey Gents, happy new year to all of you.
Brief update: the M5 is doing well a year on from buying it. Plenty of progress has been made.
1)Turns out the resonator flap was not working (even though we thought it worked we never checked to make sure, lessoned learned), we pulled off the plenum to find the incorrect diameter vacuum lines and the one-way valve was installed... the wrong way. Rectifying these things fixed that issue.
2) ABS light came on. Cleaned all the sensors and also found one of the wires from the rear right sensor had been broken (the one near the battery) fixed that and light went out.
3) Sent warning computer box away to be refurbished. False warning codes gone.
Now, onto the next thing + my question. To preserve this wonderful engine I aim to adjust the valve clearances as I feel this needs to be done. I'm aware that one needs some tools like the special bucket depressing tool, valve cover gasket, and obviously new shims. I was wondering if anybody knows where I could order s38b36 shims in SA, as well as the special tool to depress the bucket to remove the old shims? Any info on this would be appreciated.
Cheers
This is helpful. Thanks. Which Bmw mech in JHB was it if I may ask? I would pm you, but not sure how to do it in this forum.I had my shims done at a BMW Mech here in JHB. Reason was, shims take about 2 weeks to arrive from Germany. So you need to measure all your clearances, work out what shims you need, order them, wait, install and remeasure, praying that you measured correctly the first time...I took it to someone who had shims in his workshop, so it was a quick job
Buy it and put the motor in a 3 series box 😁Having said all that, the E34 M5 is not that fast, especially at altitude![]()
A Golf GTi will drive away from you, but you'll have a bigger smile on your face
Peter AEW, he is on this forumThis is helpful. Thanks. Which Bmw mech in JHB was it if I may ask? I would pm you, but not sure how to do it in this forum.
haha, nah e30 doesn't look as sleek as the e34.Buy it and put the motor in a 3 series box 😁
Remove the plenum so that you may get to the idle control valve and at the same time to the smaller vacuum hoses which need to be checked for cracks and perished ends.
When an engine is steady whilst cold and starts hunting when hot more often than not it is sucking un metered air which will show up as erratic idle when hot.
Clean the ICV with petrol by dipping it or carb cleaner,
Make sure the throttles are all at the same gap when closed or open.
Change spark plugs air filter fuel filter
Set valve clearances
Also do a fuel pressure test.
Remove fuel injectors and clean them in thinners by soaking them for a few hours whilst changing the thinners regularly.
That specific engine is low on torque in the mid range (relatively speaking) so do not expect any great performance.
The mechanic in question. Most of the troubleshooting tips he gave in this post were problems you found while fixing the car.This is helpful. Thanks. Which Bmw mech in JHB was it if I may ask? I would pm you, but not sure how to do it in this forum.
Yep, that's why I turn to this forum for advice. Plenty of clever chaps over here.The mechanic in question. Most of the troubleshooting tips he gave in this post were problems you found while fixing the car.
Unlucky...I have exactly the same situation with mine...someone used locktite to keep the viscous fan on the pump - so the water pump got damaged while trying to remove it 🤬Hey guys, its me again. It looks like the water pump on the s38 (different water pump to the m30) is in its death throws and BMW don't stock them anymore. They seem to be difficult to come by. It seems we may have to rebuild the original which I know is obviously not ideal but there seems to no alternative. Does anyone recommend a guru in SA that is capable of rebuilding such a water pump?
Thanks I will contact himSpeak to Firi he has a very good condition pump for sale original at R1500 roughly
Thank youSpeak to Firi he has a very good condition pump for sale original at R1500 roughly
OkThank you
@Benji I think made contact this morning, so he is 1st in line pending my outcome tomorrow.
Sent from my SM-S918B using Tapatalk
Hi there, we had the injectors redone properly, also replaced the o ringsHz it.. I would say, clean your injectors. I fitted the 260cc injectors on my 535 and what a transformation, but the consumption and black unburnt fuel wen cold was a issue..
