I wouldn't recommend RTA - never ever again after my last visit.
Visit One:
- Install DP - simple task which went well so I thought I'd use him again since he was very close to my work. Big mistake.
Visit Two:
- Installed new front shocks inverted which resulted in links immediately failing (Because somehow, they were installed on the reversed shocks).
- He uses shit oil - "G Tech". Whatever the fuck that is.
- Crushed my side skirt on the lift (Rubber lifting block had fallen out but no temporary one was used or a replacement requested, which I'd obviously O.K. instantly)
- Used Febi parts on mounts instead of OEM, which I only learned while picking the car up
- Invoice was a complete balls-up
Needless to say, I immediately redid
all the work elsewhere on the subsequent days. 0/10 would recommend.
EDIT: This was in Q4 2020
