New 1900hp Pininfarina Battista Goes Official
CocoPops
Automobili Pininfarina has revealed an all-new, all-electric hypercar called the Battista. Underneath the svelte, and typically Italian carbonfibre bodywork is not a highly strung V12, but a combination of four electric motors and a 120kWh battery pack that Automobili Pininfarina says will jettison the Battista to 62mph in ‘less than two seconds’. Big claims from the new Italian manufacturer, but then it has some pretty big numbers to back it up.
To start with, the Battista is based on a carbonfibre chassis borrowed from Croatian electric hypercar manufacturer Rimac. The electric motors, capacitors and batteries are also sourced from there, but although the tech is shared, Pininfarina has done lots of work to ensure that its vision of the Battista remained pure. As a result, Pininfarina did significant work on the Battista’s overall proportions, moving the windscreen forward by 180mm, giving it a more traditional Italian mid-engined supercar silhouette.
Two electric motors are mounted to each axle, and each powering a specific wheel giving the Battista full torque vectoring capability without the need for heavy and complex differentials. As mentioned above, total power is rated 1873bhp, with a staggering 1697lb ft of torque available at a standstill, enabling the Battista to hit 62mph in ‘under 2 seconds’ and 186mph in under 12 seconds. Pininfarina quote an estimated top speed of 217mph.
The battery pack itself is not of the increasingly popular skateboard variety, rather it’s a T-shaped unit that sits behind the driver compartment and runs between the two seats. The main benefit is being able to maintain an ultra-low driving position, as well as keeping more of the mass towards the centre of the car. The 120kWh battery pack should enable a potential range of up to 280 miles from a single charge.
If there was a single element that played to Pininfarina’s strengths, it would of course be design, and the Battista does not disappoint in this regard. The traditional mid-engined silhouette is correct and present, and is wrapped with a considered, subtle and sophisticated body that is dripping with appeal. The most dynamic and interesting element is the massive delta-wing motif, that runs over the tight rear haunches and informs the rear styling and floating wings that also house the tail lights. This section also holds the Battista’s active rear wing, which is the only piece of active aero on the car.
The interior is dominated by a pair of touch screen flanking steering wheel, with designers focusing on a level of symmetry from the driver’s perspective, rather than the interior as a whole. Specific trims and finishes are able to be specified to the owner’s taste, and as suspected, is a strictly two-seater interior.
We then approach the small issue of price. Automobili Pininfarina is quoting a cost of somewhere between €2-2.5 million (£1.7-2.1m), to start. This price-point puts it above even the usual hypercar space operated in or around £1m, and straight into the territory of the Bugatti Chiron. That’s a car which not only appeals on design, performance and heritage, but also execution, as one of the most stunningly put together cars in history. Can the Battista hope to compete? Well, remember it’s worth remembering that Pininfarina has not only been responsible for designing the multi-million pound Ferrari specials, but building them too. And what better CV is there than that?
Riaad
Events Organiser
In white it looks stunning, 1400kw is madness :skit:, and yet still a very decent range of 450km per charge... impressive.
Am I the only one that sees a Ferrari from the front?
TS_
I was about to say the same thing. Very clear Ferrari inspiration here. I guess they must've forgotten that their weren't working on their commission on this one.
VictorMike
It looks like a Ferrari designed by a first year design student.
German101
I see it too and I'm not a fan of that brand (bar a modified F40) at all.
NtandoN said:
:praise:
In the first photo, are the brake calipers burning?
Haha, yup, they're glowing. Stupid photoshop edit I know....
It's cool to see this tech being on show. I'd be interested to see their battery systems and layout.
