Looking for Premium Coilovers?
XM*
XclusivModz are the sole distributors of Silver's NeoMax Coilovers in SA!
These are the premium grade coilovers in SA and are the cream of the crop.
NeoMax & NeoMax R Models will be available.
Pricing From: R12 500 (Height & Damper) depending on vehicle and setup. A premium product at a brilliant price. (R14 000 Height Damper & Camber) 7-10 Delivery from date of Order.
The Following Cars will be Catered For:
BMW E30
BMW E36
BMW E46
BMW E90/92/93
BMW F80/82 M3/M4
BMW 1,2,3,5,6 & 7 Series
Also catering for the M Models
Many more cars are available, please drop us a mail with your query.
Some Quick Characteristics of the Product:
Greatest balance between performance & comfort
24 levels of dampening adjustability can be set to any preference.
JIS G3445-STKM13C (DIN2393-ST44-2) carbon steel 52mm dia seamless tube.
44mm linear characteristic internal piston provides a maximum dampening response.
Mono-tube shock design
High viscosity of IP F.A. 5W damper oil can ensure the best efficiency of shock-absorbing action.
Lower bracket height adjustability prevents the need to adjust the spring perch, offering the maximum shock-absorbing travel.
Cold-bent springs made from high strength SAE9252 steel can keep stable elastic modulus.
Powder painted steel lower bracket can match all design of brake line & ABS line holder, easy for installing.
Drop us a mail or call us if you need any info !
