Howzit guys
I need the gurus on here's assistance please. I was doing a little research on my cooling fan not working but I don't seem to get a definitive answer telling me that replacing my cooling fan will definitely fix my problems. So I'm turning to the community for help/assistance in sort my problem.
Ok so where do I start. Friday afternoon I was running some errands, I got stuck in some traffic for 15mins, it was quite hot on Friday so I had the ac blowing. Moments later I felt ac blowing hot air and then noticed my heat gauge raising. Traffic eventually start moving and the needle dropped a little but not completely. I managed to pull on the side of the road to shut down the car. Gave it a few minutes to cool off, then checked the temp but it was still high I was far from home and panicked cause peak hour traffic will be starting soon. So I started the car up and decided to get going again but I shut off the ac, low and behold the heat gauge slowly started moving back to the center. I made my way home 25km's with no issues. Car stood most of the weekend and I drove it again this morning to work, no issues with ac on. However there is no traffic going to work.
Now just before I left work on my way home I decided to put the ac on to check if my fan is working and guess what it didn't. I left the ac running while the car was idling for 5 mins, still no fan spinning but the ac was blowing cold.
What do you guys suggest I do here, by a new fan, check fuses or what would be next. I don't have a scanner so I can't check exactly what is at fault all I know is my fan is not working.
I am scared to drive the car like this fearing head gasket damage or expansion tank blow out.
Please advise.
Apologies for the long post but wanted to be as clear and thorough as possible.
Please advise.
