RealPreshaanB
Good day all, I need some assistance. I'm doing a CIC retrofit, non-idrive (BMW Professional) to CIC (not the version with the hard drive). I've done the test fit, and everything works: the head unit functions correctly, the screen works, and the controller works. The only issue I'm having is that the AUX shows up (AUX volume at full); however, there's no audio playing through. When I put everything back together and have the original head unit connected, the aux works. The car that i got everything from had the USB + aux function. Will that play a part in this, and is it just a matter of coding the unit to accept the analogue AUX signal
Any help or suggestions will be appreciated
