DarrylvanNiekerk
Hi Guys, apologies for the long post.
I have decided to go down a path I was advised not to but circumstances are such that I cannot avoid it. Due to financial constraints and the fact that my car is generally in good condition, I have chosen to go ahead with an engine rebuild.
Far too many people have advised to bin the car because it is not worth rebuilding a 320, I have been told they are rubbish and I should rather upgrade, even that I should just buy a second hand motor and be done with it. After sitting for a number of months mulling over my options I came to the conclusion that I don't have the money to buy a new car, if I sell my car in its current state I would get nothing for it and a second hand motor comes with its own potential pitfalls. Besides, I have a lot of spare time on my hands due to the current climate.
So essentially I climbed in boots and all and embarked on a full rebuild and refresh so I can get back the car I really enjoyed driving. It is a 2006 320i with sports pack and on a good day was such a pleasure to drive. A few years ago the gremlins started with an intermittent misfire, just a single hesitation. We could not pin it down and eventually this grew into a complete cluster mess which ended with a burned exhaust valve and a broken piston which scored the cylinder wall.
I have spent hours on the internet, watching Youtube, reading forums, to try and figure out how to deal with the situation but not only were there so many conflicting views but there was a distinct paucity of information on 4 cylinder engines. Almost everything is available on 6 cylinders, I suppose because either the 4 cylinder guys are advised to walk away or the only people posting on these sorts of repairs are the 6 cylinder guys.
I tried to extrapolate from the videos how the 4 cylinder would be similar but alas there are some very distinct differences and I have ended up learning as I go along. It was really scary in the beginning because it felt as if I was in uncharted territory but I have gained a lot more confidence as I have gone along and started stripping pretty much anything I can to see if it needs a refresh or replacement.
The reason for this very long winded post is partly to document my travels but also to make this space available for those who have issues with their 2 litre engines who cannot get their questions answered. I am by no means an expert, this is not my field and I haven't done anything mechanically minded on a car for near on 20 years. But, I have learned so much and figured out how simple most things are if you take your time and are practical about it.
Where I am right now is as follows:
The car finally gave up the ghost almost a year ago and I limped into a garage in Alberton in the hopes they would be able to get me back on the road to get home. No such luck. I left the car there for diagnosis and got a ride home. They called me in and showed me the damaged piston and cylinder wall and advised on a replacement engine as the cost for repair would be too high. If I had a mechanic do the job the costs would be astronomical.
The engine had been partially stripped already so I had the car towed to my house and parked it in the garage for almost 8 months. I finally unpacked all the parts from the boot and tried to piece together what everything was. I spent may hours bending into the engine bay looking at how everything was held together and how it might come apart and in the end bit the bullet and stripped the entire front end to get access. I am very glad I did this as each step of the way I could properly see what I was doing and avoid stripping bolts or screws.
Instead of trying to get the engine out on its own, the bolts that join the gearbox to the engine are almost impossible to reach, I decided to take the gearbox out with the engine. This meant I had to remove the exhaust and heat shield, decouple the drive shaft and gear linkage and then hoist the engine out. It was all surprisingly easy to do. I did mark the position of drive shaft to gearbox flange to avoid a mismatch and imbalance or shudder when reassembled.
The other reason I am glad I went this route is as I was stripping things I could see where maintenance had been lax, corners cut, and how oil had gotten into almost everything. It was also at this stage I realised some of the main differences between the 4 and 6 cylinder engines, apart from the obvious. There has been much discussion about failing DISA Flaps and for the life of me I could not find mine. That is because the 4 cylinder does not have any -the closest it comes is swirl flaps in the inlet manifold. Another thing I came across were the oil non return valves in the block which keep oil up near the head for quick lubrication on start up. These are a service item, BMW don't even have them on their system any more, and with a 6 cylinder you can access them with the engine in the car from the wheel well. Sadly with the 4 cylinder they are only accessible with the head separated from the block.
I have since found that my engine mounts are worn, the gearbox mount bushes have sheared, brake hoses need replacing, clutch and flywheel is gone and so much more. Because the engine hds been moving with the worn mounts something was rubbing on the brake lines and these are very nearly worn through in a few places, this could definitely ended in disaster.
The route I have chosen to go is to have the block bored and resleaved, although only one cylinder is damaged and the rest are good replacing only one could cause the cylinder next to it to become oval. I had the option of a used N42 block with pistons but there were subtle differences and the cost of redoing the block is actually not that much. 3 of my pistons are good, they aren't that worn, so I need to get a 4th piston to match.
The head is in decent condition but the exhaust valve stem guides are worn and need replacing. A new gasket set will give new valve stem seals and when the engineering company do the head they will put it all back together again for me. I did have the unfortunate joy of having the cable tie which held the VANOS unit together snap and had to figure out how to put the inlet unit with finger followers back together again.
I have spent ages trying to find who sells what for the car and getting prices together for everything so I know what the final damage is going to be. I have decided to go for a single mass flywheel & clutch replacement because it is not only around half the price but will be a few kilos lighter. There is apparently additional vibration introduced with this but I am not against feeling the car a bit more. Brake hoses from BMW are well over R3k so it will be cheaper to put in braided steel hoses as they are cheaper, last longer and will give better brake pedal feel.
Luckily most of the peripheral parts are in good condition and mostly only need a bit of a clean and new gaskets. My biggest concern was the oil pump as they are no longer made and are apparently very prone to failure. I took my time stripping this and found that luckily there has been no damage from stray engine bits and with a proper clean and rebuild will be fine.
I am happy to add to this as I go along and post pictures if requested. At the end of it I want to attend to a few cosmetic issues with the paint, have the high wear items in the interior such as gearknob, stearing wheel and seat bolsters attended to and I will have an almost brand new car.
So far my expected cost is around R40k all told.
