Cats going bad
NB92325
I need some advice. I suspect my catalytic converters are unhappy. For a while I smelled something akin to wet paint in the exhaust fumes which I think is fine, but today for the first time ever I got the unmistakable smell of sulfur as I was unloading the boot after driving the car.
I see there are other explanations for the smell related to fuel ratios etc but most likely candidate is cats.
I don't have any other symptoms yet (fuel use is normal for the 325i at about 9.5kpl, power seems normal, no engine light), so perhaps early days? Is there any way to be certain about this?
What I need advice on is what to do if it is indeed bad cats? No ways I'm replacing them. But if I delete them, do I just do the secondary ones or also those on the headers, which it seems will then require tuning shenanigans to fool the ECU?
Also, any idea what this may cost (assuming I do the delete and do what's required to not make my car sound like a tincan)?
Cheers!
Sent from my SM-S916B using Tapatalk
AshG108
You can replace with down pipes and get cat foolers if you not going with software.
Sent from my SM-S928B using Tapatalk
Well in this case branches/headers bud, since it is a non-turbo car.
But agreed, replace and fit the foolers BUT also get to a decent shop @NB92325 so that the car doesn't end up with that tinny sound, but maintains the nice, 6 cylinder rumble with extra bass
