bmw328
Good morning to all,
Recently bought a fairly clean (considering the age) 2002 BMW X5 3.0D Auto marked as non runner, "Not getting gears, forward or back".
It had the GM transmission...
When checking out the car, I checked the gears and it all of a sudden had forward and reverse gears (Stunned the seller).
Ended up driving car +-100Km with some slippage on full throttle in higher 5th gear before it lost gears again and it had to be towed the final 20km.
What I have done:
X Drained about 5L transmission fluid, changed filter and added +-8L fresh fluid back.
X When engine is running, unplugging "transmission electronics" to basically rule out electrical failure by transmission only running in hydraulic mechanical mode. (reverse and one gear forward)
Strange thing is. When transmission is COLD, it does select gears, but once it heats up (Example 5-10 min driving, it looses everything.) I have even tested this theory while its idling. (At first forward gears & reverse, 5min later nothing)
Any advice, comment would be appreciated. Failed clutches or torque converter?
What I have done:
