Post Reply
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
E90 320d front wheel bearing - question.
25-03-2019, 11:35 AM
Post: #1
Hey folks......
Diagnosed the front left wheel bearing is kla - usual ticking noise when moving forward slowly, rattle when going over bumps, hum/grinding from that corner of the car - made worse when turning.
Busy trying to find a replacement. Issue now is there is an option of hub with ABS sensor and one without.
Which one is which for my car? dunno anymore
TIA.
Find all posts by this user
25-03-2019, 11:49 AM
Post: #2
RE: E90 320d front wheel bearing - question.
Check with the dealership. I changed e46 wheel bearings and the pricing was quite good. Plus they'll check according to your VIN so you'll get the right one.
If you're changing the Hub too then it may get expensive with the stealers.
25-03-2019, 11:51 AM
Post: #3
http://www.realoem.com/
Put your VIN in there and get a Part number.
Then work from there.
[Image: nick sig2_1674483441.jpg]
25-03-2019, 11:59 AM (This post was last modified: 25-03-2019 11:59 AM by Mc Member..)
Post: #4
(25-03-2019 11:49 AM)Jeremy.d Wrote:  Check with the dealership. I changed e46 wheel bearings and the pricing was quite good. Plus they'll check according to your VIN so you'll get the right one.
Thanks.
Went this route already.......R3k. omg waiting
Having a look around.
(25-03-2019 11:51 AM)Nick Wrote:  http://www.realoem.com/
Thanks for this, does help indeed.
Will need one with the ring for the ABS sensor to pick up.
Now I know at least. Thumbs
The following 1 user Likes Mc Member.'s post:
Nick
26-03-2019, 02:26 PM
Post: #5
Sitrep:
Found a replacement, had it installed quickly between meetings.
Strangest thing is that the bearing coming off didnt have any play or the more common signs of issues.
Yet it was night and day difference and the rumbling under sideways load is gone, the rattles over bumps are gone, the skittish and unsettled feeling from the front of the car is also gone.
Even the mechy looked and me and asked if I was sure that the wheel bearings are the issue when he pulled the old one off.
Anyway........onwards and upwards we go.
Thanks for the assistance above.
Nick
30-04-2019, 12:38 PM
Post: #6
Hi
I have a knocking noise that i hear ever so often when turning my wheels or reversing. could this be wheel bearing issue also?
whats the cost of this replacement?
E90 320D MSport
Ex: E46 318i MSport
Ex: VW Golf 3 Gti
Ex: VW Mk1 2 door
30-04-2019, 12:49 PM
Post: #7
(30-04-2019 12:38 PM)DeanoBlado Wrote:  Hi
It may be possible but you may need to try and diagnose further I am afraid.
Throwing good money at a bad diagnosis of a problem can become costly.
It could even be control arms for instance.
Are those the only symptoms you can describe?
Post Reply
User(s) browsing this thread:
1 Guest(s)
