Post Reply
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
19" wheels and ET's on M235i?
12-09-2018, 06:37 PM
Post: #1
Hi guys
Considering getting 19" wheels for my car but not sure what the widest ET's I can run on the front and rear of a M235i? If anyone can assist it would greatly be appreciated.
Find all posts by this user
13-09-2018, 09:23 AM
Post: #2
RE: 19" wheels and ET's on M235i?
Im sitting with the same issue, it is very hard to find the right wheel offset for the 2 series.
I have done some reading, considering you can go with 12mm spacers with the stock wheel, the standard wheel specs are:
Front 7,5JX18 ET:45
Rear 8JX18 ET:52
0.5J difference is an additional 6mm wider and, and each "1" less of the ET is 1mm outter.
therefore on the rear's you can go 8.5J ET45 which will take the wheel out by 13mm, which should be fine for fitment.
I haven't tested the above as yet on the car.
Rishie Rish
Current: 2014 F22 BMW M235i
EX: 2011 E82 BMW 135i Msport DCT (Hybrid)
Ex: 2006 Audi A3 2.0T DSG FRC-Tuned
Ex: '96 Jetta VR6
Ex: '91 E30 325i
Ex: '96 Jetta VR6 2.9i
Instagram: RISHIE_RISH89
Facebook: http://www.facebook.com/DJ.Rishie.Rish
Music Is What Feelings Sound Like Joy
13-09-2018, 09:25 AM
Post: #3
when i bought wheels for a diff vehicle though i did a lot of google checking specs & seeing how fitment looked.
current: BMW E92 M3 (bearings could be fcukd)
13-09-2018, 09:40 AM
Post: #4
Check this link out, all about fitment etc ..........
https://www.wheel-size.com/size/bmw/x3/2...m-20d-eudm
Hope this helps,
Cheers.
[Image: 4 pipe 5_9850016809.jpg][Image: 1_8588773575.jpg][Image: imag0391_2786668599.jpg]
13-09-2018, 07:03 PM (This post was last modified: 13-09-2018 07:03 PM by OPC.)
Post: #5
(13-09-2018 09:23 AM)Rishie Rish Wrote:  Im sitting with the same issue, it is very hard to find the right wheel offset for the 2 series.
Front 7,5JX18 ET:45
Rear 8JX18 ET:52
This is true man, Also the rim type I like is a rim with a concaved look to it and seems this is not a optionThumbdown
Really wanted a BBS CI-R type of wheel in a 19"
14-09-2018, 10:01 AM
Post: #6
I had the following fitted on my M235i.
Size: front 8,5J x 19 ET38 and rear 9,5J x 19 ET48
Style: M double-spoke 622
BMW Part Number: 3611 7849661 and 3611 7849662
Fitment was perfect - Flush and No Tyre poke, no need for spacers either.
Here's a link to my ad for them:
https://www.bmwfanatics.co.za/showthread.php?tid=85727
14-09-2018, 01:09 PM
Post: #7
(13-09-2018 09:40 AM)supertramp Wrote:  Check this link out, all about fitment etc ..........
Hope this helps,
Cheers.
This site seems very conservative
it lists
530d 228hp 245/35ZR19 / 275/30ZR19 8Jx19 ET20 / 9.5Jx19 ET32
and I'm running
245/35ZR19 / 265/35ZR19 8.5Jx19 ET12 / 9.5Jx19 ET17 and theres still about 10mm room on the rear, possibly 5mm maybe 7mm on the front that could space out.
Current Rides
2007 530d MSport (DP, 76mm exhaust, RK Motion tune, OEM M6 wheels)
2012 X1 2.0D MSport
1996 200 Si Camry
[Image: photo from sashchern_5592516823.jpg]
17-09-2018, 07:14 AM
Post: #8
I have seen M235i's running wit a 8.5J with ET35in the front and 9.5J with ET45 in rear without any rubbing. Still not easy to get rims that I like with these offsets Thumbdown
17-09-2018, 12:44 PM
Post: #9
(17-09-2018 07:14 AM)OPC Wrote:  I have seen M235i's running wit a 8.5J with ET35in the front and 9.5J with ET45 in rear without any rubbing. Still not easy to get rims that I like with these offsets Thumbdown
Yup, shouldn't be any tyre rub - even had an HnR drop (20mm) and with two rear passengers there was no rubbing.
It is difficult to get wheels that fit. It seems only M performance and some X series wheels have the right offset (if you want to go OEM). Some aftermarket stores (e.g. ADV1, VMR, OZ) have fitment options if you buy directly.
The best wheel I've seen on the 1/2 series has to be a 19" CSL wheel - its on a red M235i that I sometimes see at the Bellairs Mall
17-09-2018, 01:42 PM
Post: #10
ive seen an X5 wheel on a 1 series too Skit
Yesterday, 06:16 AM
Post: #11
Also like that style wheel, looking at the VMR V710 Fencelook
Post Reply
User(s) browsing this thread:
1 Guest(s)
