Post Reply
Thread Rating:
  • 4 Vote(s) - 3 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Coilover / Springs Thoughts
27-07-2018, 10:19 AM
Post: #1
Need some feedback
I drive a substantial amount, my car needs a little low.
After checking and pricing from coilovers to springs.
My past vehicles all had Eibach lowering springs as I can't go too low but as I'm taking a 3 months off of work I can and would like to enjoy the very low life and here's my question.
Would it be better to go adjustable coilovers or do lowering springs.
I am leaning more to adjustable coilovers as they can remain on the car and I can adjust when I go back to work.
Now on to the coilovers, will it be worth it for me to spend the north of ZAR15000 on BC coilovers when I'm barely going to change stuff apart from height. And how horrible is FK, Maxtraxx and JOM?
Before the BC boys scream get BC, just note I'm thinking short term use for everyday and not track , oh and I drive a little 320i Auto.
Pics of that gap that needs some closing.
The front
[Image: img_20180727_094516_2687366362.jpg]
The rear
[Image: img_20180727_094524_5134285390.jpg]
Side note : Tyres, Yes they mixed tyre (not only the size but tyre brand, same brand in the front and same brand at the back.) It was a test fit and I just never got to changing back to stock rims as they need to be restored. These on the car must still get new tyres.
Find all posts by this user
27-07-2018, 10:44 AM
Post: #2
RE: Coilover / Springs Thoughts
You can fit the cheap coilovers, They wont perform nearly as good as the better brands.. but they will do what you need them to do, lower the car. the ride quality will not be anywhere close to a quality coilover though..
27-07-2018, 10:57 AM
Post: #3
personally i would do H&R springs and shocks if you choose to go very low..but obviously you can't adjust..i would personally only fit coillies if i can fit a top brand.
current: BMW E92 M3 (bearings could be fcukd)
27-07-2018, 11:16 AM (This post was last modified: 27-07-2018 11:18 AM by Preshen14.)
Post: #4
I don't mind springs at all, The only irritation for me is that I like the front to sit lower than the rear, With coilovers that is easier to accomplish.
However, To daily the car with Coilovers can end up being very frustrating, It can be harsh even when raised, So yes you can have all the ground clearance but the ride can still be shit compared to stock. "Expensive coilovers" are not only beneficial on the track but also street use, Coilovers with Dampers obviously assists with bumps and bends a whooole lot better.
As tempting as coilovers sound, I would go for an aggressive H&R setup. Think about it carefully and logically, Don't end up regretting anything.
EDIT : If it was not your daily I would have recommended Coilovers without a doubt.
Current : 2004 E46 330i MtechII A/T
Stainless Exhaust | Decat | Coilovers
27-07-2018, 11:56 AM
Post: #5
ja you still get different spring heights with coilies & progressive springs as well
27-07-2018, 12:28 PM
Post: #6
H&R sport and Koni, works 100% for me.
The following 1 user Likes Dewald Basson's post:
Preshen14
27-07-2018, 03:25 PM (This post was last modified: 27-07-2018 03:26 PM by Preshen14.)
Post: #7
He will have to go more lower than H&R sport with the drop the he wants.
27-07-2018, 03:39 PM
Post: #8
Perhaps I am misunderstanding.
But you want your car as low as it can go for 3 months, thereafter back to daily conditions.
1) Go proper coilovers so solve for both cases, don't buy cheapies
2) Buy springs and fit them for the 3 months, then put OEM springs back after that.
Thumbs
Current:
'14 F30 335i MSport Alpine White III, Coral Red, Sat Nav, iDrive touch, PDC + reverse cam, Harman Kardon, N55 222.4wkw | 413wnm STOCK
'16 F30 318i LCI Manual, Alpine White III, Black Leather
[Image: banner final_1261154562_8282635603.png]
[Image: m_fanatic2_8387882621.jpg]
Mods: Optic Blue Lamin-X fogs, VPS light shields, CF Splitters, Mirrors, Ducktail spoiler, Aluminium interior trim upgrades...
Retired BMWs:
'12 F30 320d
'12 F20 118i
'09 E90 LCI 320i M-Sport
'07 E90 320i Excl
'91 E30 325iS Evo I
27-07-2018, 06:30 PM
Post: #9
Thanks guys.
I have to say I'm shocked there wasn't any, "just get BC" or "BC FTW"
Ideally I don't want to buy and keep for 3 months then return to stock.
Seems like BC or fully adjustable coilies is the best bet, issue I have with them is everyone I know that has BC in has everything set in the middle apart from height which seems like a waste.
Will have to think longer about it
27-07-2018, 07:24 PM
Post: #10
(27-07-2018 03:25 PM)Preshen14 Wrote:  He will have to go more lower than H&R sport with the drop the he wants.
Springs is the halfway real life solution IMO
27-07-2018, 10:04 PM
Post: #11
Im running coilover on the 120d and its our daily. Does school runs, weekends, everything. In fact even took it to raceday 2 weeks back.
Get a coilover setup and you wont look back. I did not want to break the bank, but I wanted something better then BC as I found them noisy in the 2 cars I went to test drive that had them fitted. I opted for ST V1s which are made by KW Suspensions and the pricing was very similar to BC.
Rennzport is now an agent for KW and ST and if you interested, you can pop us an email on rennzport@live.co.za and will quote you accordingly.
Kindly include you Model, Year model and vin number as well.
Regards
Firi
[Image: signature_2082411609.jpg] - - - - - - - - - - [Image: 120d avatar_6603350746.jpg]
[Image: bmw-official-events-signature_8286350658.jpg]
28-07-2018, 10:35 PM
Post: #12
Thanks @Firi and email sent
30-07-2018, 06:34 PM
Post: #13
Hi
I fitted max trac Coiloverson my e90 that i purchased from Shaun , for my daily.
Well i just wanted the tyre gap closed, and that's exactly what it did.
Ride is not so bad and not bouncy at all.
Looks really sweet also, but i'm sure i will raise it a little at a later stage , as speed bumps do become a bit of an issue and i knew what i was getting myself into smile bounce
Ex 2011 BMW 335i MPACK - 199WKW STOCK
Ex 2011 BMW 320d MPACK - DAMN TARMAC RIPPER
CURRENT 2010 AUDI A6 - SPACE WAGON - 2.0T
Ex 2006 VW JETTA 5 FSI 2.0T BWA DSG
Ex 1993 Jetta 3 Clx - 2l ADY
Ex 1992 Honda Dohc - Screamer Of Note
EX 2008 - E90 - 325i White - Sport Pack
Ex 2000 - Toyota Rxi 20VT
Ex 2007 - Toyota Run X Trd
Ex 1997 - Honda Civic Vtec
Eish thats all i can say
31-07-2018, 09:05 PM
Post: #14
Anyone fitted the Vogtland springs or coilovers.?
[Image: bantam rocam 1.6i_2487780912.jpg]
[Image: bmw e46 330i_7176807271.jpg]
Bmw E46 330i
Ford Bantam
31-07-2018, 10:00 PM
Post: #15
Don’t buy cheap coil overs , I had Jom at one stage and let’s just say it made an expensive car feel cheap . At the end of the day you pay for what you get Thumbs
Post Reply
User(s) browsing this thread:
1 Guest(s)
