Post Reply
Thread Rating:
  • 3 Vote(s) - 2 Average
  • 1
  • 2
  • 3
  • 4
  • 5
E90 creaking sound when turning steering
19-07-2018, 12:24 PM
Post: #1
Hi Guys
been having a issue with my e90 pre-FL , lately when turning the steering at low speeds there is a creaking sound which i cannot seem to figure out, took it to a workshop and they said its the control arms, tie rods and rack ends so had those changed but after picking up the car, the sound is still there, did anybody experience this? if so what was the issue?
Also the car starts shuddering above 100km/h not sure why because balancing and alignment was done. this car is driving me crazy.
Im in Durban btw.
Preno
Current
BMW 323i 2007
2015 Kia Rio 1.4Tech
Ex:
BMW 323ci 2000
1997 BMW 318is Motorsport
2013 Polo vivo 1.6
Find all posts by this user
19-07-2018, 12:58 PM
Post: #2
RE: E90 creaking sound when turning steering
Did your steering have a play on it before changing those mentioned parts? That would have indicated that you needed to do tie rod ends, etc.
A shudder can be a number of things, buckle wheels, spacers (If you have).
This may sound stupid but, can you describe the sound better? Lol. Also, how is your shocks?
Current : 2004 E46 330i MtechII A/T
Stainless Exhaust | Decat | Coilovers
19-07-2018, 01:21 PM
Post: #3
Check the strut top mountings.
19-07-2018, 01:45 PM
Post: #4
WithStu check all the bolts holding the whole steering rack in place also.
2011 120d Coupe (Black - Yin)
2012 125i Coupe (White - Yang)
2009 Z4m Coupe ( found a new home )
07 Audi A4 ( Passed onto father inlaw )
19-07-2018, 03:05 PM
Post: #5
Just turn the music up.dunno anymore
The following 1 user Likes Jeremy.d's post:
Preshen14
19-07-2018, 05:04 PM
Post: #6
(19-07-2018 01:21 PM)johndoe Wrote:  Check the strut top mountings.
Have a similar issue, workshop claim its the front shock mountings that need to be replaced...
19-07-2018, 05:14 PM (This post was last modified: 19-07-2018 05:16 PM by Prenevan.)
Post: #7
(19-07-2018 12:58 PM)Preshen14 Wrote:  Did your steering have a play on it before changing those mentioned parts? That would have indicated that you needed to do tie rod ends, etc.
No steering had no play on it, just listen to the guys and changed it. shocks are fine and it sounds like either metal rubbing on metal or plastic rubbing against metal. 1 wheel does have a small ding on it but doubt it will create the vibration from 100km/h i may be wrong tho
What do i check on the top strut mountings or shock mountings?
Tried turning the music up but it only happens at slow speeds like when in a parking lotdunno anymore.
Preno
Current
BMW 323i 2007
Ex:
BMW 323ci 2000
2013 Polo vivo 1.6
19-07-2018, 06:11 PM (This post was last modified: 19-07-2018 06:13 PM by johndoe.)
Post: #8
you will have to remove them to check it. when were they last replaced?
20-07-2018, 08:47 AM (This post was last modified: 20-07-2018 08:53 AM by Preshen14.)
Post: #9
That sounds like mountings to me
(19-07-2018 06:11 PM)johndoe Wrote:  you will have to remove them to check it. when were they last replaced?
+1, Almost impossible to check without removing your strut/shock
20-07-2018, 10:43 AM
Post: #10
Il have to check it out this weekend, one other thing tho, when the car is on a 2 pole lift and turning steering there is no noise, but when back down the noise is extremely loud for like 2 or 3 days and then it softens down. Searched the net and cant find anyone with a solution.
Preno
Current
BMW 323i 2007
Ex:
BMW 323ci 2000
2013 Polo vivo 1.6
20-07-2018, 10:47 AM
Post: #11
Yes because you unload the suspension when on the lift.
20-07-2018, 12:21 PM
Post: #12
Hi, what you can try is put your hand on the coil spring when the vehicle is on the deck and then turn the steering - be careful you don't crush your hand. If you do feel a vibration on the coil spring it would be worth your while to remove the strut and test the mounting.
As for the vibration when driving - check if your rims haven't been rep[aired. I have had it several times where repaired rims are the cause. Would suggest you get donor rims and then retest and see if the vibration is gone.
Cheers
John Lodder
Service Manager
Leo Haese BOSCH Hatfield
HAVAL Hatfield
GWM Hatfield
Pretoria
012 366 3000
[email protected]
[Image: jvr_1784_preview_9049289529.jpg]
20-07-2018, 01:59 PM
Post: #13
(20-07-2018 12:21 PM)[email protected] Haese Bosch Hatfield Wrote:  Hi, what you can try is put your hand on the coil spring when the vehicle is on the deck and then turn the steering - be careful you don't crush your hand. If you do feel a vibration on the coil spring it would be worth your while to remove the strut and test the mounting.
Cheers
Hi John, will try it this out when get a chance, any idea where to get the mountings just in case?
Will try and source another set of rims and test it out, thanks for the info.
Preno
Current
BMW 323i 2007
Ex:
BMW 323ci 2000
2013 Polo vivo 1.6
Post Reply
User(s) browsing this thread:
1 Guest(s)
