Post Reply
Thread Rating:
  • 1 Vote(s) - 1 Average
  • 1
  • 2
  • 3
  • 4
  • 5
225/40R19 or 235/35R19?
13-07-2018, 02:19 PM
Post: #1
Howzit
I need advice on what size tire I need to get?
I have 255/35R19 at the back.
Dankie
[Image: 2yoerra.jpg]
[Image: 2hy8pjb.jpg]
Find all posts by this user
13-07-2018, 02:22 PM
Post: #2
RE: 225/40R19 or 235/35R19?
Fronts 225/40 which is the oem size
Can also use 235/40 in the front and 265/35 19's
The front should have always have a higher profile then the rear in a staggered fitment setup
13-07-2018, 02:33 PM
Post: #3
(13-07-2018 02:22 PM)NBN Wrote:  Fronts 225/40 which is the oem size
okay cool just need to find the right balance now as i could not find the semis in 255/30r19. so went for 255/35r19. means i need to go for 225/40r19
13-07-2018, 02:41 PM
Post: #4
Yip, you need to try keep the overall diameter the same.
The 255/35 will have sidewall height of 89.25mm (35% of 255)
The 225/40 will have a sidewall height of 90mm (40% of 225)
If just using for drags, I don't think the size of the fronts should matter to much, but the rear overall wheel diameter and width would effect things the most.
Current - F20 2018 M140i
Current - E92 2008 M3
Current - E46 2002 M3
Ex - E92 2008 335i N54 FBO
Ex - E46 2004 325ci
Ex - E36 1996 318is
Ex - Ford Escort
13-07-2018, 04:03 PM
Post: #5
Is your car lowered? the higher/taller profile could cause your arches to rub
13-07-2018, 04:43 PM
Post: #6
Yes my car is dropped. So will need to go with a lower profile
13-07-2018, 10:12 PM
Post: #7
What tyres you planning on getting? I recently got Michelin Pilot Super Sport. Been happy with them, ride allot nicer than the rft Bridgestone s001 I had
Current:
M135i F20 Estoril Blue 6MT - Weekend Warrior
Opel Corsa Utility 1.4 Sport - Daily
SO:
320d F30 MSport Alpine White 8sp A/T
Gone but not forgotten:
Peugeot 207 HDi 1.6 HDi
Honda Civic Type R FN2 NHB
My Build Thread: M135i
Post Reply
User(s) browsing this thread:
1 Guest(s)
