Post Reply
Thread Rating:
  • 24 Vote(s) - 2.75 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Red Devil - a Kadett 200iS Story
31-01-2018, 05:41 AM
Post: #61
RE: Red Devil - a Kadett 200iS Story
She has started up , all is good. I removed the engine and stripped it apart, sent the block in to skim the deck.
Put everything back together after a heat up start to check for leaks i found a leak that seemed to be water coming out between the block and head to the outside, i removed the head and installed a normal carbon gasket, after heating up the same happened but found that it was a water pipe behind the head.
Now still a few things to do.
1. Relocate radiator fan
2. Upgrade brakes
3. Wiring and programming Dicktator ECU.
4. Exhaust
5. Charge Pipes
6. Piggy bag fuel pumps.
7. Modify and spray front bumper.
8. Replace front doors
9. Replace rear Bumper
Current :
2009 BMW 125i
1994 Kadett 200iS
1974 Beetle
EX :
1995 BMW 328i
Find all posts by this user
The following 1 user Likes Gordvisr's post:
Geek_320
31-01-2018, 07:24 AM
Post: #62
Glad to see you found the leak. Can't wait to see this build finished!
31-01-2018, 07:26 AM
Post: #63
Leka man it's a relief to find out what was giving you a headache. Almost there
BMW 335i e90 manual N54 - His
VW Scirocco R DSG - Hers
10-02-2018, 10:22 PM (This post was last modified: 10-02-2018 10:24 PM by Gordvisr.)
Post: #64
So she is up and running currently. Running Std management and std Injectors for now, will run like this for about 1000 Km then i will start with the mods on the nose for the Intercooler and the plumbing..... Cannot wait to go boosted, have done about 100 Km and all looking good, had some issues here and there with hoses, replaced them and went on. It has been a journey so far , the build started in Nov 2016 , learnt a lot during the build and glad i did not give up. Will update shortly after running in.
Current :
2009 BMW 125i
1994 Kadett 200iS
1974 Beetle
EX :
1995 BMW 328i
21-02-2018, 06:58 AM
Post: #65
https://www.youtube.com/watch?v=ucMf0PuaE7Q
Just a short clip after the first successful Start-up.
Exhaust was not connected yet.
Current :
2009 BMW 125i
1994 Kadett 200iS
1974 Beetle
EX :
1995 BMW 328i
21-02-2018, 07:58 PM
Post: #66
Exciting times indeed. Well done and congrats
F25 X3 35i M-Sport (The family car)
130i M-Sport: Alpine Upgrade, BMWP Intake, BMWP Exhaust
Corsa C Ute 2l 16v Tebbo Bluebiggrin : Build Thread Here
22-02-2018, 05:20 AM
Post: #67
Thank you Gav
Current :
2009 BMW 125i
1994 Kadett 200iS
1974 Beetle
EX :
1995 BMW 328i
29-03-2018, 02:40 PM
Post: #68
Had some spare time on my hands, Started and completed the Harness.
[Image: harness before_6469372641.jpg]
[Image: harness after_4203161080.jpg]
Then completed the Plumbing...sort off
[Image: engine top view_6533962418.jpg]
And fitted a coil pack instead of the dizzy, still waiting for the "new" back plate to be made up.
[Image: coil pack_2596787624.jpg]
At around 16h00 on tuesday i finished installing the harness and ecu but still need to get the laptop sorted out, will do that when i have some free time on my hands again, currently running between work and hospitals, also a big thanks to DannyOpc for his input and help.
Current :
2009 BMW 125i
1994 Kadett 200iS
1974 Beetle
EX :
1995 BMW 328i
Tinuva
27-04-2018, 08:51 PM (This post was last modified: 27-04-2018 08:54 PM by Gordvisr.)
Post: #69
So we are boosting now, had a few issues with wiring, got it sorted quickly and got it road tuned, can drive with it for now but waisting time to go into boost, the clutch is slipping big time. Waiting for some off time again to pull the motor, I have a suspicion they messed up the flywheel when they skimmed it.
[Image: dsc_0192_8885545404.jpg]
[Image: dsc_0198_3665581322.jpg]
Still a lot of work to be done cosmetically, will get to that on a later stage.
Current :
2009 BMW 125i
1994 Kadett 200iS
1974 Beetle
EX :
1995 BMW 328i
The following 2 users Like Gordvisr's post:
Ebo, Geek_320
27-04-2018, 10:38 PM
Post: #70
I admire your passion for the old girl, keep it up, look forward to seeing a video of her in full boost mode.
[Image: 23170803612_b806dc0716_n.jpg]
2004 BMW 325i M Sport Individual - Messing Metallic - 120k km - Decat - 67mm tailpipes - CF Splitters - 18" Individual Style 152s - White LED upgrade - BMW Performance Gearknob - Brushed Allu Trim/Wood Trim - Armrest - FSH
The following 1 user Likes Karthik's post:
Gordvisr
27-04-2018, 11:44 PM (This post was last modified: 27-04-2018 11:47 PM by Gordvisr.)
Post: #71
When we get there, I'll make one and post it here, for now I have to be patient, unfortunately.smile bounce
I do have a passion for this car, also hats off for her, she went through a lot together with me and always remained by my side, her first "dump" was on 500001 Km.
Current :
2009 BMW 125i
1994 Kadett 200iS
1974 Beetle
EX :
1995 BMW 328i
07-05-2018, 09:38 PM (This post was last modified: 07-05-2018 09:55 PM by Geek_320.)
Post: #72
(27-04-2018 08:51 PM)Gordvisr Wrote:  So we are boosting now, had a few issues with wiring, got it sorted quickly and got it road tuned, can drive with it for now but waisting time to go into boost, the clutch is slipping big time. Waiting for some off time again to pull the motor, I have a suspicion they messed up the flywheel when they skimmed it.
She is a beauty finally followed up on the post and liking what you done there, I mean she really looks good and sounds sexy as hell Praise
Current: F30 320i individual
Its all in the eyes
[Image: angel_1326331002.png]
The following 1 user Likes Geek_320's post:
Gordvisr
08-05-2018, 07:35 AM
Post: #73
Last week Thursday, removed the engine to swop out flywheel and clutch kit, was slipping for the first three days but seemed to stop. The flywheel that came out will be sent in later this week together with clutch kit to make me a button clutch.( Double work yes but this flywheel was balanced together with the crank assembly so it need to go back in) This coming Friday afternoon will do some final road tuning. Did about 3000 Km so far, everything looks to be holding up quite nicely, Hopefully by next week will be able to pick up the boost and have some proper fun.
Current :
2009 BMW 125i
1994 Kadett 200iS
1974 Beetle
EX :
1995 BMW 328i
15-05-2018, 12:15 AM (This post was last modified: 15-05-2018 12:20 AM by Gordvisr.)
Post: #74
(27-04-2018 10:38 PM)Karthik Wrote:  I admire your passion for the old girl, keep it up, look forward to seeing a video of her in full boost mode.
https://youtu.be/MfXHqxK-O2k
https://youtu.be/EVpyLZkh--o
Made two short clips, she is pulling nicely, still place for improvement, she lags quite a lot between shift changes, that might change if i get the "bigger" flywheel back and we still need some fine tuning. It feels good to go boosted finally.
Current :
2009 BMW 125i
1994 Kadett 200iS
1974 Beetle
EX :
1995 BMW 328i
15-05-2018, 01:40 AM
Post: #75
Bravo patience paid off Thumbs how much boost you going to be running 0.9? sounds good. How's the torque steer on the car?
15-05-2018, 04:11 AM
Post: #76
Torque steer is there, with the lighter flywheel it is not that bad but if it can catch you off guard, it can end up in a mess.
We got it tuned up to 1 bar, a bit scared to go higher now, injectors or pump also holding a bit back. Want to try 750cc injectors later, and still need to piggy the fuel pump, currently running internal pump alone.
Current :
2009 BMW 125i
1994 Kadett 200iS
1974 Beetle
EX :
1995 BMW 328i
15-05-2018, 07:15 AM
Post: #77
That turbo flutter smile bounce Cartel
Current: E92 325i M LCI
Current: Audi A4 B8.5 1.8T
Ex: E90 323i Exclusive LCI
Ex: E90 320i Individual LCI
[Image: naman_5196753591_3577692508.png]
15-05-2018, 08:01 AM (This post was last modified: 15-05-2018 08:03 AM by DSC.)
Post: #78
Looks good .
Since you an Opel fan .. here you go . I had similar set up in one of my Kadett . PICS are before the turbo plumbing .
[Image: gs1_1205124775.jpg][Image: gsi 2_812295568.jpg]
This was the 16v Turbo Built . 350kw . [Image: gsi4_8651028643.jpg]
The following 1 user Likes DSC's post:
///Maniac
15-05-2018, 01:28 PM
Post: #79
Thank you man.
Current :
2009 BMW 125i
1994 Kadett 200iS
1974 Beetle
EX :
1995 BMW 328i
15-05-2018, 07:43 PM
Post: #80
What happened to these cars ?
On the 8 valve, what size injectors did you use ?
I remember seeing the White one.
Current :
2009 BMW 125i
1994 Kadett 200iS
1974 Beetle
EX :
1995 BMW 328i
Post Reply
User(s) browsing this thread:
1 Guest(s)
