Thread Rating:
  • 1 Vote(s) - 2 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Falken is SHIT!!
#61
I'm using 912's on the 540 no issues. Must be said I burst now & again to let the big girl fill her lungs every now & again but I don't do any sustained high speeds for long periods of time.
Honda CB400 - For the traffic
Fiesta RSI SWR Conversion - For the school run
E36 328i Convertible - For the summer time
E39 540i - For Soul /o(O)(O) \ (illlllllll) (llllllllli) / (O)(O)o\
Reply
#62
(24-06-2014, 03:44 PM)born2boost Wrote: The problem is related to Toe settings. If the alignment was set correctly and within spec then I suspect wear on the steering linkages somewhere, which I also notice is among parts that were not recently replaced.
This is further confirmed by the fact that there are patches worn down instead of uniform wear like in the case of too much negative camber.
I see that you have also lowered the car abit with the H&R springs. Sometimes, even when using the best of springs out there, the suspension geometry changes and can induce 'Bump Steer'. This means that while your suspension is compressing, the alignment settings including the Toe, fluctuate continuously and can result in terrible tyre wear as you've experienced
As a short term solution, I would dial in a little more Toe in up front and monitor wear for the next few thousand km...Also...replace the tie rod ends and rack ends on the steering.
Long term you might want to either look at some sort of bump steer correction or alternatively go back to the stock springs.
If the car is left as is, no matter what tyre you put on there...it will probably wear down the same way.
good explanation man. makes sense now
2016 Focus RS
Click: Youtube Channel
Click: Build Thread
The following 1 user Likes Rommies's post:
  • Speedy
Reply
#63
The following is some more proof of how crap Falkens are.
Over December, myself and company attended a track day.
I had these really old Michelins that cried out for a beating. So they were asking for it. Str8pimp
And I didn’t want to ruin the new front Yokohamas on the M pars.
So for comparison, this is how the Michelins in front looked after the track day:
[Image: WP_20141223_005_zpsd7d58655.jpg]
Held up pretty well I would say.
Unfortunately not so much can be said from the Falkens on the rear of the same car:
[Image: WP_20141223_007_zps04cadbd6.jpg]
[Image: WP_20141223_008_zpsdddc6d46.jpg]
Look how they ripped themselves to pieces. Chunks of tyre came apart.
[Image: FordTappetcover1.jpg]
If everything seems under control, you're just not going fast enough - Mario Andretti
Reply
#64
Is this the same set that couldn't be balanced?
___
Current:
2011 E70 LCI X5 40d XDrive
2009 E90 330d lci MSport
- Xcede SW + Xflow DP & Exhaust
- N54 Intercooler
- XHP Gearbox Flash
2003 E46 330d
EX:
2007 Polo 1.4 trendline
2006 E90 320d
2007 E90 320d msport Promotec + DP
2012 E70 LCI X5 3.0d XDrive
2009 Jeep Wrangler Saraha Unlimited
Reply
#65
Yes it is
Reply
#66
tread blocks look too small for track use...
Reply
#67
(21-01-2015, 01:32 PM)moranor@axis Wrote: tread blocks look too small for track use...
Once that helmet slides over your head, any tyre becomes track use compatibleCrazylaugh
Reply
#68
Surely any tyre out of balance pushed hard on a track can end up like that...
Never used falkens. Always stuck to the premium brand. Although I heard fairly decent stuff about them.
___
Current:
- N54 Intercooler
- XHP Gearbox Flash
2003 E46 330d
EX:
2006 E90 320d
The following 1 user Likes DieselFan's post:
  • Ralf*
Reply
#69
Well good riddance they are now out of my life
Reply
#70
Rule #6: Treat all tires like they deserve to die.
The following 1 user Likes Sankekur's post:
  • Fordkoppie
Reply
#71
(21-01-2015, 01:45 PM)Fordkoppie Wrote: Well good riddance they are now out of my life
get some RE002 they are a very good trackable street tire
The following 1 user Likes moranor@axis's post:
  • Fordkoppie
Reply
#72
Already got some Yokohama ADVAN Neova AD08s
Reply
#73
even better Bluebiggrin
  • Fordkoppie
Reply
#74
Fordkoppie, I'll show you what premium brand tyres look like when used on a GTi performance course at Kyalami.
[Image: IMG_8690.jpg][Image: IMG_8691.jpg][Image: IMG_8692.jpg][Image: IMG_8693.jpg]
[Image: IMG_8694.jpg][Image: IMG_8695.jpg][Image: IMG_8696.jpg][Image: IMG_8697.jpg]
[Image: M_logo.png]ad [Image: M_logo.png]an
The following 1 user Likes H|TM@N's post:
  • Fordkoppie
Reply
#75
(21-01-2015, 02:26 PM)H|TM@N Wrote: Fordkoppie, I'll show you what premium brand tyres look like when used on a GTi performance course at Kyalami.
Wow. Are those the assymetric 2s? They are awesome street tyres though.
___
Current:
- N54 Intercooler
- XHP Gearbox Flash
2003 E46 330d
EX:
2006 E90 320d
Reply
#76
The first 4 looks normal for track use, but I still cant believe how the ones in the wet turned out
Reply
#77
Yes Asymmetric 2's and Bridgestone s001's. They both show the same degradation. Street tyres and track time do not go well together.
The semi's on my ex 1M did not look half bad after a full track day at Kyalami.
Look, don't get me wrong, I will not fit Falkens on any of my cars, not even the Toyota Tazz.
After 1 full track day at Kyalami.
[Image: IMG_4031.jpg]
  • Fordkoppie
Reply
#78
toyo proxes t1 sport Bluebiggrin FOR THE WIN Bluebiggrin
i put 265's on the rear of my 530d e39. running style 65 m5 wheels.
paid like 2.x k each... and accross all the reviews etc... the proxes t1 sport is the closest (apparently) you'll get to pilot sports...
pilot sports in the same size is like 5 or 6k each
/o(O)(O) \ (lllllllll)(lllllllll) / (O)(O)o\
Reply
#79
I believe you get what you pay for, and this is proof why premium or top branded tyres are priced so high compared to "budget" tyres.
[Image: vdzhdja9uhv0ms9pn60e.jpg]
P1000 Wrote:Real men don't do motorplan
The following 1 user Likes Doomsdaya's post:
  • Fordkoppie
Reply
