Post Reply
Thread Rating:
  • 1 Vote(s) - 2 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Falken is SHIT!!
24-06-2014, 09:47 AM (This post was last modified: 24-06-2014 09:48 AM by Rommies.)
Post: #41
RE: Falken is SHIT!!
If im not mistaken the toyo t1 proxes are currently on special.
225/35/19 proxes t1 sport - R2399-00
235/35/19 proxes t1 sport - R2049-00
255/35/19 proxes t1 sport - R2499-00
265/30/19 proxes t1 sport - R2799-00
285/35/20 proxes r888 - R5699-00 (Nissan GTR)
The Falken FK453 cost about the same as the Toyos 225/35/19 I purchased.
So I opt for the Toyos off course.
2016 Focus RS
Click: Youtube Channel
Click: Build Thread
24-06-2014, 11:11 AM
Post: #42
i have had Falken 452 and its the worst tyre i have owned to date, car sounded like all bearings were shot, Toyo's any day..
Current:
F80 M3
Golf 7R
RR Sport Autobiography
Find all posts by this user
24-06-2014, 02:38 PM
Post: #43
(24-06-2014 09:32 AM)Kimeran Wrote:  So you would recommend the Falken FK453 for high speed driving?
only if no other tyre manufacturer existed, then the FK453, would be the tyre of choice for high performance vehicles and high speed driving.
however there are better quality tyres available, more suited to high speed driving, but if you are on a budget, and still want a tyre "designated" as high performance by the manufacturer, then the FK453 would be the better choice in the FALKEN range.
/o(O)(O) \ (lllllllll)(lllllllll) / (O)(O)o\
https://www.facebook.com/ralf.t.schulz
24-06-2014, 03:44 PM (This post was last modified: 24-06-2014 03:48 PM by born2boost.)
Post: #44
The problem is related to Toe settings. If the alignment was set correctly and within spec then I suspect wear on the steering linkages somewhere, which I also notice is among parts that were not recently replaced.
This is further confirmed by the fact that there are patches worn down instead of uniform wear like in the case of too much negative camber.
I see that you have also lowered the car abit with the H&R springs. Sometimes, even when using the best of springs out there, the suspension geometry changes and can induce 'Bump Steer'. This means that while your suspension is compressing, the alignment settings including the Toe, fluctuate continuously and can result in terrible tyre wear as you've experienced
As a short term solution, I would dial in a little more Toe in up front and monitor wear for the next few thousand km...Also...replace the tie rod ends and rack ends on the steering.
Long term you might want to either look at some sort of bump steer correction or alternatively go back to the stock springs.
If the car is left as is, no matter what tyre you put on there...it will probably wear down the same way.
[Image: c25e7131-93a0-479a-9eae-530269e37609_zpsaf5b8012.jpg]
///Mpowered
The following 2 users Like born2boost's post:
boost3d, Fordkoppie
25-06-2014, 11:20 AM
Post: #45
[Image: 1620667_orig.jpg]
The following 3 users Like MaX's post:
ChefDJ, Loom, Redline
25-06-2014, 11:29 AM
Post: #46
(25-06-2014 11:20 AM)MaX Wrote:  [Image: 1620667_orig.jpg]
I'm going to use this pic in a new thread and sticky it under the wheels section for easy reference.
Thanks Thumbs
My thread - sold
Click here to view the network of forums hosted by TheFanatics.co.za | Click here to find out more about advertising on our network of forums | Click here for a list of our current advertisers | Click here for the forum rules and guidelines | Click here and check your region for any past and upcoming events and get-togethers | Click here to find out how to gain ///Member status
25-06-2014, 11:39 AM
Post: #47
"stolen and shared" Thumbs
25-06-2014, 12:20 PM (This post was last modified: 25-06-2014 12:25 PM by moranor@axis.)
Post: #48
If I remember correctly this car had some sagging no name brand lowering springs on that Chris got with the car the H&R raised it somewhat
also Chris was complaining that the no name brand springs were too soft making the car bottom out even more easily...
with this being the case there would be less bump steer action with the H&R springs than the previous setup
Chris also chose the mild drop from H&R these generally do not cause any real geometry problems it is the H&R Low version that is designed for show cars that can have this problem if geometry corrections are not made
25-06-2014, 12:30 PM
Post: #49
(25-06-2014 11:29 AM)ChefDJ Wrote:  I'm going to use this pic in a new thread and sticky it under the wheels section for easy reference.
Thanks Thumbs
Good idea. Stumbled upon this on another forum and thought it would be a good fit for this thread. My initial thought was also to blame the patchy wear on the tires. Learn something new everyday Thumbs
25-06-2014, 10:20 PM
Post: #50
My next set of rubber will be Falkens.
And from SpeedwayThumbs
Current Rides
2013 Audi Q7 3.0 V6 TDI S Line
2006 Audi A3 Sportsback 2.0T S-Tronic Ambition FRC ECU & S-TRONIC TUNED
(Ex BMW'S 2006 335i, 2006 X3 30d 2003 330i, 2002 325i 2000 540i, 1998 318i MS, 1992 325i MEX)
(NON BMW'S 2006 A4 AVANT, 2003 POLO 1.6, 2000 200 STI, 2000 RSI 20V, 1999 GTI, 1998 RSI 20V)
(1997 RSI 20V, 1997 MICROBUS, 1993 RSI T/C, 1992 GLI T/C, 1986 GLI T/C)
The following 1 user Likes YUBEN's post:
ChefDJ
25-06-2014, 10:23 PM
Post: #51
(25-06-2014 10:20 PM)YUBEN Wrote:  My next set of rubber will be Falkens.
Mine still look brand new after almost 20k km on them. 912's Thumbs
My thread - sold
The following 1 user Likes ChefDJ's post:
YUBEN
25-06-2014, 10:35 PM
Post: #52
Unfortunately I do not think it is fair to generalise based on a few bad experiences.
I used Falken before with success.
Yet I had an issue with Conti SCIII
Current Rides
sash
26-06-2014, 07:51 AM
Post: #53
(25-06-2014 10:35 PM)YUBEN Wrote:  Unfortunately I do not think it is fair to generalise based on a few bad experiences.
True,
Maybe the topic should be more like 'my falkens are SHIT' or ' This batch of Falkens is SHIT'
Not taking anything away from the problem with the tyre, but I wont say all Falkens are bad. For anybody looking to purchase Falkens they need to do sufficient research into the pros and cons.
No, no, he didn’t slam you, he didn’t bump you, he didn’t nudge you… he *rubbed* you. And rubbin, son, is racin’. – Harry Hogge, Days of Thunder
Current Rides
2007 530d MSport (DP, 76mm exhaust, RK Motion tune, OEM M6 wheels)
2012 X1 2.0D MSport
1996 200 Si Camry
[Image: photo from sashchern_5592516823.jpg]
The following 1 user Likes sash's post:
YUBEN
26-06-2014, 02:34 PM
Post: #54
I do not think Falken is that bad.
I have used a few different good brands of tyres on a turbo charged Vauxhall Astra (my track car) and my 330D sportwagon on staggered 18's when I lived in the UK.
The Toyos Proxes T1-S sidewalls were too soft for the weight of the BM. Had to run stupid pressures to minimize the wear on the edges, especially on the front. On the Astra I would not try anything else except the Toyo R1R.
On the BM I tried Vredestein and they were good. Family member had 452's on a 330i and praised them very much. I fitted some and still have them on and I will def. use them again!
I had a wheel on the Astra that left "patches" like that on the tyre even after I replaced and rebuilt the suspension fully. Took the Astra to Tony from wheels in motion in the UK(suspension specialist) for my setup. I found out later that the rim was round but had a slight wobble that would cause the patchiness like flat spots. (also made it very difficult to get balanced)
Had the rims straightened and refurbished and my problem was gone.
Our potholes and speed bumps in SA does not help the issue either!!
26-06-2014, 03:43 PM
Post: #55
Same with me I replaced my rear contis with Falkens and they are waaaaay better. My contis were fitted a year and few months ago and they bubbled cracked Thumbdown
Current rides
1995 E36 325i [Unfinished Monalisa]
2004 E46 330D M-sport [167wkw 556nm]
Ex Rides
1998 160i Conquest Rs
2012 Yamaha FZ6R - Stock
26-06-2014, 03:44 PM
Post: #56
Was there no comments on the car when you bought it. My first guess would be the car was in an accident at some point..
26-06-2014, 03:52 PM
Post: #57
(26-06-2014 03:44 PM)Nicbyte Wrote:  Was there no comments on the car when you bought it. My first guess would be the car was in an accident at some point..
OP's car is a 540i... An E34 AFAIK. Highly doubt you'll get MP comments on a car that old
26-06-2014, 03:58 PM
Post: #58
its 18 years old New_all_coholic
[Image: FordTappetcover1.jpg]
If everything seems under control, you're just not going fast enough - Mario Andretti
26-06-2014, 04:01 PM
Post: #59
Rofl On an e34 540i-6. I don't think so.
[Image: M_logo.png]ad [Image: M_logo.png]an
The following 1 user Likes H|TM@N's post:
Fordkoppie
26-06-2014, 04:24 PM
Post: #60
(26-06-2014 03:58 PM)Fordkoppie Wrote:  its 18 years old New_all_coholic
just legal then for a good spanking Rollsmile
The following 1 user Likes moranor@axis's post:
Fordkoppie
Post Reply
User(s) browsing this thread:
1 Guest(s)
