Thread Rating:
  • 7 Vote(s) - 2.14 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Bottoming out
#61
(05-09-2012, 10:16 AM)Sabretooth tiger Wrote:
(05-09-2012, 10:15 AM)Thunder Wrote: With it on the alignment pit I pulled and pushed on almost everything that I thought might be the cause but no luck.
Will try and get her up in the air this weekend to see if I can find the rattle.
Lucky for me the only part of the speedbump I hate the most is when the front wheels go over, thats where I mostly hit, Cry bumper still high enough to clear most of them Joy
Will update again soon.
also check I noticed your wheels rub when you turn hard.
Jip they do.
Maybe I have to go down to 215s in front and not 225 like they are currently.
Evil inside
Current : Yamaha FZR 1000 - custom (Frankenstein)
Ex:Opel Kadett(Stripes)Sold
E36 318i (The Witch) Sold
Hyosung Comet 650R (The Grok) Sold
Yahmaha R1 (Black Widow) Writen off
Honda Ballade [size=xx-small]Sold
Reply
#62
Okay, so while my wheels were off I took some photos of rim size and the scraping spots.
Also kinda figured out my car isn`t bottoming out its the tyre hitting where it isn`t suppose to.
Here is a pic of where.
[Image: DSCF0009-1.jpg]
and
[Image: DSCF0004.jpg]
its ont the fender just inside the wheel arch.
then all the scraping spots.
[Image: DSCF0005-1.jpg]
[Image: DSCF0003-2.jpg]
[Image: DSCF0002-2.jpg]
[Image: DSCF0001-1.jpg]
and the back wheels
[Image: DSCF0018.jpg]
fixed most of the front ones due to the plastic trimming not seated correctly, pushed it all into place now I can turn without all that scrapping.
Then here is the info i found on the inside of the mag.
[Image: DSCF0016.jpg]
[Image: DSCF0015-1.jpg]
[Image: DSCF0013.jpg]
[Image: DSCF0012-1.jpg]
Evil inside
Reply
#63
sorry thunder,but have to say this
its all the ice cream youve been eatingBiglol
are your rims et correct?
Reply
#64
I suspect your offset (et) is wrong for your car.
Reply
#65
To be honest I dont know anymore.
Really confused. Bangdesk
Evil inside
Reply
#66
it look's like the offset is way wrong
Reply
#67
(01-10-2012, 06:50 AM)Dippies Wrote: it look's like the offset is way wrong
Where do you see that?
Want alles wat in die mag staan is grieks vir my Fencelook
Evil inside
Reply
#68
ambie will be better to explain this to you Thumbs
Reply
#69
Thumbs Ty
Evil inside
Reply
#70
There should be nothing wrong with a 7J ET35 on your car.
What size tyres are you running all round? And are the rear wheels the same spec?
[Image: 550i_2_9618496634.jpg]
Current:
2010 BMW F10 550i
BMW Goodbyes:
2005 BMW E90 330i Exclusive | 2002 BMW E46 330i Exclusive (Facelift) | 2006 BMW 550i MSport
Reply
#71
Calling Abmi.
Reply
#72
(01-10-2012, 08:08 AM)SP33DYV Wrote: Calling Abmi.
I've been Icon9 Bluebiggrin
Current:
2010 BMW F10 550i
BMW Goodbyes:
Reply
#73
All round wheels are the same 225/45 R17.
Doomsday did say that the fact that it is Dunlop SP6000 might have an influence due to the fact that Dunlop tyre`s rubber is thicker than onther tyres?Fencelook
Evil inside
Reply
#74
(01-10-2012, 04:07 PM)Thunder Wrote: All round wheels are the same 225/45 R17.
Indeed I did Bluebiggrin but I had 225/45/17 SP7000D Dunflops & the sidewalls was as thick as tractor tyres Rofl
For 17inch e36 rims, Bmw recommends 7.5j in front with an ET of 41 & either 225/45/17 or 235/40/17 tyres.
http://www.willtheyfit.com/index.php?wid...mit=Submit
I use this wheel offset calculator to see what difference it would make if I change either spec of rims or tyres or both. From what I can see your rims are narrow compared to OEM spec.
[Image: vdzhdja9uhv0ms9pn60e.jpg]
P1000 Wrote:Real men don't do motorplan
Reply
#75
So what do you guys suggest I do to sort it out?
Evil inside
Reply
#76
(01-10-2012, 05:42 PM)Thunder Wrote: So what do you guys suggest I do to sort it out?
You can change to a lower profile tyre but that still might not solve your problem as the rim width & offset is incorrect. Only way you won't have issues is to have OEM spec rims with 235/40/17 tyres as 225/45/17 tyres have thick sidewalls irrespective of brand & don't bode well with a 40mm drop.
Reply
#77
Maybe I should get other brand fitted and see what it does?
Evil inside
Reply
#78
Why don't you just get some spacers and see what happens.
Reply
#79
(01-10-2012, 07:32 PM)SP33DYV Wrote: Why don't you just get some spacers and see what happens.
That will move them even further out so not gonna work. Fishwack
Evil inside
Reply
#80
Ok, so take 3mm off the rim mounting face.Fencelook
Reply
