Thread Rating:
  • 58 Vote(s) - 3.26 Average
  • 1
  • 2
  • 3
  • 4
  • 5
BMW Differential Tutorial, with pics.
#41
Hey Marius, been a while. Love what you did to the RSi. Bluebiggrin, have you got a BMW yet?
Im in the process of piecing together a big turbo build for the e36, 2.0lt 4cyl turbo.
Reply
#42
ja man too long, what you doing these days.
No not yet man, bmw are for you rich folk lol
thanx man
sounds lekker man, tell me more sounds interesting
[Image: 90688RSI.jpg]
Objects in the rear view mirror appear further away than they really are.
Reply
#43
(10-11-2009, 09:34 AM)88RSI Wrote: ja man too long, what you doing these days.
thanx man
Will on another thread, this one is going OT.
Reply
#44
sorry man my bad, come chat to me in my introduction thead man, I would like to hear what is the latest
Reply
#45
(09-11-2009, 12:43 PM)Gizmo Wrote: Well, if you want a little more acceleration you can go from your 3.64 to 3.91 ratio. I can build you a 3.91:1 LSD for your E34 for R1800, shoot me a PM.
What LSD does the E36 4door M have... ? What can it be modded too ?
This sounds interesting... might be a better mod then the HID headlight Excited
Reply
#46
(10-11-2009, 10:40 AM)M_POW Wrote: What LSD does the E36 4door M have... ? What can it be modded too ?
It has a type 210 large case 3.23:1 LSD so any type 210 gear sets will fit inside it.
Reply
#47
Thanks Gizmo,
The diff ratio's are confusing me... When meet up at the next meeting your can explain to me how it works etc Bluebiggrin
Reply
#48
JHB ppl,
Need help changing my diff oil... I dont have the no. 14 allen socket. Also what size washers will be required ?
Any where i take it in jhb price...
Reply
#49
While we on the sub. my LSD was slipping on the right side after re shim and clean it twise. strip my mo*r and made it a LSD LOCK'r , know wat i mean CO2.
Reply
#50
Hi there Gizmo,
Just signed up here to ask for some advice for my E34, 535i. Guys tried to steal it last week and I think they wrecked the diff totally, when I put it in drive or reverse I get no movement, just a grinding from the rear end.
Does the diff seem like the right diagnosis?
Now I've been looking around and Autofever has used replacements for R2500, but the idea of a LSD for less is appealing, can you still do this? What ratio would be best? More acceleration would be cool, but I'm a bit concerned about petrol consumption.
The broken thing was my daily driver too. Sad
Reply
#51
That sucks dude... sorry man Sad
I will be on the other side if anybody needs me Bluebiggrin
Reply
#52
Please tell me what is the ratio in the E39 540i (A) diff and if it has LSD
[Image: images1-1-1.jpg] E39 540i Steptronic 1997 (no sunroof WTF Iono )
Reply
#53
(30-03-2010, 05:43 PM)zaleonardz Wrote: That sucks dude... sorry man Sad
Thanks mate, was the second time in 2 weeks they tried too. First time they wrecked my ignition, then I fixed that and they wrecked it again, got the car about 1 km away and wrecked the diff.
How, I don't know.
(30-03-2010, 08:18 PM)iandickie Wrote: Please tell me what is the ratio in the E39 540i (A) diff and if it has LSD
According to this chart, it's 2,93. No word on it being an LSD, I would assume not, but I'm sure an expert will know more. Wink
I'm assuming mine is 4.27. Does a lower number, eg 3.91, mean the engine is revving higher at a given road speed? Or the opposite?
Reply
#54
I have an e46 dedicated track car with 3.38 gearing and a Quaife LSD. Looking to change gearing to either 3.73 or 3.91. Is it possible to use the ring and pinion from an older 188 type diff, e.g. the 3.73 from an e34 525 from 1989, or is it necessary to get them from e.g. an e90?
Reply
#55
(24-04-2010, 01:22 PM)oreo Wrote: I have an e46 dedicated track car with 3.38 gearing and a Quaife LSD. Looking to change gearing to either 3.73 or 3.91. Is it possible to use the ring and pinion from an older 188 type diff, e.g. the 3.73 from an e34 525 from 1989, or is it necessary to get them from e.g. an e90?
I got a 3.64 from an X3 for a customer. It went into an E46 330i with a quaife and used as a dedicated track car.
No ring and pinion from type 188 or 210 will fit onto the e46 diff.Censored
Reply
#56
Is it possible to get a 3:15 gear set to mod my E34 540?
The stock 2:93 is way too long, just want to bring the ratio down a little.
Reply
#57
Thanks for the quick response! Do I understand you correctly that the internals of the X3 diff fitted in the housing for the e46? In that case, do you know whether all newer internals from 3-series E9X, 1-series E8X, Z4 E85/E86, and X3 E83 will fit in the E46 housing, or will one have to change the entire differential?
Reply
#58
Hey Gizmo,
This thread rocks your write ups are awsome, I performed a diff swap in my E30 what a bloody mission lol, one of the bolts didnt want to come loose, it ended up being a 2 full days and 2 night job.
I wanted to ask though, with my E36 325i Convertable does it have a LSD or open diff? if its not an LSD would you be able to swap the internals for me to make in an LSD and at what cost?
I also wanted to ask, would you be able to change the ratio of the diff to give me more acceleration?
[Image: sig_new_5373837985.jpg]
Build Thread:
E89 Z4 35i Build Thread
E89 Z4 35i Turb DIY
Current:
2009 E89 Z4 35i sDrive DCT
Previous:
2004 E46 330i
2005 Volvo S60 2.0t
2008 Yamaha R6
2004 E46 330D
1994 E36 M3 German spec
2009 Yamaha R6
2002 E39 525i
1996 E36 325i convertible
1997 E36 325i
2004 Yamaha R6
1998 E36 328i Individual
1984 E30 323i 2 door
1998 Mazda Astina
1987 Golf II GTI
1988 Golf II CSL
Reply
#59
Only the e36 M3 had a LS diff, no other E36 got it.
I can build you a custom ratio E36 limited slip diff for R3000. Many ratios to choose from....
Reply
#60
I would like a ratio thats going to give me the strongest pull away but I don't want it to affect my top speed tooooooooo much, I know you can't have both, but I would be happier with a stronger pull away and slightly less top speed as I don't drive my car at top speed very often, I don't really want to end up in prison lol.
Build Thread:
E89 Z4 35i Turb DIY
Current:
Previous:
2004 E46 330i
2005 Volvo S60 2.0t
2008 Yamaha R6
2004 E46 330D
2009 Yamaha R6
2002 E39 525i
1997 E36 325i
2004 Yamaha R6
1998 Mazda Astina
1987 Golf II GTI
1988 Golf II CSL
Reply
