Post Reply
Thread Rating:
  • 58 Vote(s) - 3.26 Average
  • 1
  • 2
  • 3
  • 4
  • 5
BMW Differential Tutorial, with pics.
23-09-2009, 03:57 PM (This post was last modified: 05-10-2009 03:12 PM by Gizmo.)
Post: #1
So I thought I should educate the BMW masses with my knowledge of BMW differentials. Here goes.
Earlier BMW models were nice in the fact that gear-sets and LSD units were interchangeable. Any BMW running the Type 188 (small case) gear-sets in the diff are swappable. Same thing goes for the Type 210 (large case) gear-sets.
Type 188 cars:
All E36 models, except the 3.2lt M3.
All E30 6cyl models.
All E34 models, except the M5 and 540i.
All E32 6cyl models.
Type 210 cars:
E46 M3 and E36 4door M3.
E34 M5 and 540i.
E32 740i and 750i.
All E38 models.
E39 V8 models, could be all models but not sure.
Here are pics of 2 E34/E32 diffs, 1 E34 and 2 E36 diffs. The two large case (type 210) E32/E34 limited-slip diffs on the left. A small case (type 188) E34 diff in the centre. Two 3.15:1 limited-slip E36 diffs on the right.
[Image: SDC10811.jpg]
Here is an exploded view of the internals of a type 188 open diff.
From left to right: Two output shafts, Open center-portion, Ring gear, Speed trigger wheel, Pinion gear, Input flange, nut.
[Image: SDC10812.jpg]
Here is the type 188 E34 case, below it is the type 210 E32/E34 case. Note, small case has 6 bolts, big case has 8 bolts.
[Image: SDC10813.jpg]
Type 210 output shaft, 36mm dia. Type 188 output shaft, 30mm dia.
[Image: SDC10817.jpg]
[Image: SDC10818.jpg]
[Image: SDC10819.jpg]
With the output shaft removed you can see the limited-slip center-portion, it has the allen key hexagonal shaft.
[Image: SDC10814.jpg]
Open center-portions have a round shaft.
[Image: SDC10815.jpg]
All BMW diffs have tags saying if its limited-slip (S) and the ratio.
[Image: SDC10824.jpg]
[Image: SDC10822.jpg]
Here is the oil I use for Limited-slip diffs.
[Image: SDC10820.jpg]
[Image: SDC10821.jpg]
BMW changed the differential design on the later models with type 188 gear sets like the E46, these won't work with the type 188 Limited-slip center-portions, pity 'cos I wanted one in my 330i. The only option is from Quaife @ +R10 000...
Oh btw, the two e36 3.15:1 LSD diffs are for sale @ R1800 each. The two large case diffs are for Uber Soldat and Clutchplate.
Any questions as to what ratio your car has I can find out for you. Got any other questions?
Find all posts by this user
The following 13 users Like Gizmo's post:
323i e46, 328ii, Andy1GP, danieljames, Fordkoppie, JayDrft, Johnny135i, NavZ, Rayzor, Serg_ZA, Spiro, UpNcOmiNg!, zippy320
23-09-2009, 04:24 PM
Post: #2
RE: BMW Differential Tutorial, with pics.
Gizmo man, for interest sake will they Fit my 316i??
Wish I had the money for it. One day I might ask you for one Bluebiggrin
Check out My EX Car : 2000 E46 318i
[Image: Signature.jpg]
Check out my videos on :
YouTube
23-09-2009, 05:35 PM
Post: #3
Thanks Gizmo...very interesting indeed. Thumbsup2
I still don't know why the e90 335 models did not come with an LSD. the open differential is just not good enough.
23-09-2009, 07:34 PM
Post: #4
what are the options on the 335? the few on the net are still very expensive.....how did you make up you mind?
23-09-2009, 09:46 PM (This post was last modified: 24-09-2009 10:12 AM by clutchplate.)
Post: #5
cool beans, thanks Gizmo, I really appreciate the trouble man ! ...
just picked up my 3.64 LSD ...
woohooo !! Excited Clap Bluebiggrin Excited Clap Drool Drool Icon9 ..... New_all_coholic ...
[Image: avatar8.png]
24-09-2009, 02:22 AM
Post: #6
I got a diff question. What causes ring and pinion wear? Like premature wear.
2008 E90 335i AT - RB Turbos
251km/h- 1km Sprint Stock Turbo's
256km/h- 1km RB Turbos
2016 Audi RS3
2015 Golf 7 1.4TSI
2014 Golf 7 R
2014 Golf GTI
2015 Golf GTI
24-09-2009, 06:58 AM
Post: #7
@Gizmo......
u state in your post that the internals are interchangeable between the e36 and e30 diffs, am i correct? so would it be possible to use an LS unit from and e30 diff in an E36 328 diff?
if so can u do it?Bluebiggrin
[Image: autox_zpsefa43770.jpg]
24-09-2009, 09:20 PM
Post: #8
(23-09-2009 05:35 PM)645Nm Wrote:  Thanks Gizmo...very interesting indeed. Thumbsup2
The 335i is already too close to the M in terms of performance. And according to my dealer even the M sales are suffering because of that. Another reason why the new engine will have 1 turbo, and be a little less tunable.
25-09-2009, 09:18 AM
Post: #9
(23-09-2009 04:24 PM)andrewbuch Wrote:  Gizmo man, for interest sake will they Fit my 316i??
Yes, its a direct fit.
I have the same problem with my 330i...
(24-09-2009 02:22 AM)George Smooth Wrote:  I got a diff question. What causes ring and pinion wear? Like premature wear.
I suppose torque is a good killer, heat for that matter too. The quality of oil used is important too, Royal Purple make quality stuff which racers swear by.
(24-09-2009 06:58 AM)Mohammed_A Wrote:  @Gizmo......
Yes that is correct, I can swap them over for you.
25-09-2009, 11:39 AM
Post: #10
Hey Gizmo, the guy from gearbox hasn't phoned me yet today..
also man, would appreciate if you are able to help me swop my internals ?
if u can, when will u have some time bro ?
Greetings..
25-09-2009, 04:53 PM
Post: #11
(25-09-2009 11:39 AM)clutchplate Wrote:  Hey Gizmo, the guy from gearbox hasn't phoned me yet today..
Greetings..
next week.
25-09-2009, 09:33 PM
Post: #12
(25-09-2009 09:18 AM)Gizmo Wrote:  [quote='George Smooth' pid='18590' dateline='1253751773']
I had a Quaife LSD fitted about 3000km prior and I got a feeling it was a botch job.
2016 Audi RS3
2015 Golf 7 1.4TSI
2014 Golf 7 R
2014 Golf GTI
2015 Golf GTI
28-09-2009, 12:00 PM
Post: #13
Who did it for you? What kind of oil was used?
28-09-2009, 10:02 PM
Post: #14
They used the oil recommended by Quaife with no additives etc.
2016 Audi RS3
2015 Golf 7 1.4TSI
2014 Golf 7 R
2014 Golf GTI
2015 Golf GTI
02-10-2009, 04:03 PM
Post: #15
Hey clutchplate, you need to get the E39 M5 diff cover to make it work. Here you can see your LSD diff casing with the M5 cover bolted on. A custom bracket is needed to bolt the front of the diff to the subframe.
[Image: e32m5coverov3.jpg]
[Image: difftopmh6.jpg]
Here is the E39 M5 diff.
[Image: 2b40ff81ro6.jpg]
02-10-2009, 05:46 PM
Post: #16
Hey Gizmo great information!!! Thank you for sharing...
Its a pitty I didn't have this info a couple of weeks agoBawling
From what I understand the 3.2L e36 m3 3.23:1 210 large case diff would of been the one to go for me?? I would like to get one of those M5 diff's to fit is it possible to get them to fit in the e36 m3 rear sub?
Dirt cheap price on those 3.15 ls diffs btwThumbsup2
05-10-2009, 03:26 PM
Post: #17
Hey Uber, I jacked up my dad's '91 M5 to take some pics of the diff. Its the E34/E32 Type 210 large case limited slip diff seen here:
[Image: SDC10826.jpg]
[Image: SDC10827.jpg]
And here is yours, Uber.
[Image: SDC10829.jpg]
05-10-2009, 04:55 PM
Post: #18
Gizmo, just got a price from BMW for the M5 diff cover .. the damn thing is R 4580 ... its insane bro !
06-10-2009, 10:57 AM
Post: #19
(05-10-2009 04:55 PM)clutchplate Wrote:  Gizmo, just got a price from BMW for the M5 diff cover .. the damn thing is R 4580 ... its insane bro !
Good god! Yet a non-///M cover is only R1300. Shows you how BMW rip off M owners... Might as well make a custom mounting plate for the rear too, would be the cheapest way.
I will try find out how much I can get the cover for.
06-10-2009, 12:33 PM (This post was last modified: 06-10-2009 03:11 PM by Gizmo.)
Post: #20
Ok, got hold of my new parts guy, I can get the M5 diff cover for R1300.
I just jacked up my mom's '01 540iA and took some pics.
As you can see, the diff cover has the same mounting points onto the subframe as the M5 but that cover won't bolt onto the E34/E32 diff casing. Also, the input flange is larger on the E39, Im not sure if these can be swapped over but it doesn't matter for clutchplate 'cos you're getting a custom propshaft anyway.
[Image: SDC10830.jpg]
[Image: SDC10831.jpg]
[Image: SDC10832.jpg]
Post Reply
User(s) browsing this thread:
1 Guest(s)
