OBD2 Coding/Fault Scanners? Any in Cape Town (anywhere) I can borrow, if not which to buy?
JordanB
Hi everyone,
I'm looking at the following OBD2 device, Vlinker BM+ (link). Im not sure if there are any better options in South Africa? I dont want to wait 2 months for import because I need it in the next few days for a repair to my car. I want to be able to use BimmerCode and BimmerLink.
I would however, prefer to find a OBD2 device that allows me to use BimmerLink/Code on my phone for my BMW, but also download other apps to connect to most other cars like Toyotas, etc, because of family vehicles. I have found this vGate MC+ (link)
ALSO:
If anyone in or near Cape Town has a decent OBD2 scanner that I can use with BimmerLink and Code or Carly I would be evergrateful and 100% give you a pack of thank you beers for letting me drive out to borrow it šŸ˜„
Maljan
Takealot has adapters, but delivery is by oxcart. I ordered one last Thursday. Delivery was going to be on Monday, then it was Wednesday and now it is tomorrow. I live in hope.
JordanB
I want to use a Bluetooth one so I can connect my phone (ios) to it and use BimmerCode, Im worried they dont support BimmerCode or brick my cars computer because they bad
Maljan
Do not buy a cheap Bluetooth adapter online. You may have a hard time getting the software needed for your phone and end up with a desk ornament. If you really want such an ornament, I have one. It was cheap enough, so I couldn't be bothered with the hassle of returning it. I thought of proposing a swop for a couple of Castle Light cans, but I don't want to rip you off.
The adapter cable did arrive this morning. Hopefully my other el cheapo code reader will now reveal the secret inner thoughts of my '02 530i. If not, I will go shopping for a better one.
PS: there are quite a few code reader apps on the Google Store. Maybe one of them will work with my desk ornament. I have not tried yet.
Solo Man
What do you want to do. I have Bimmercode on my phone and the necessary dongle that goes into the OBD2 port. What BMW are we talking about? I am next to Tyger Valley Mall
Nastaliq
The best is ISTA i have complete kit fish hoek area
Gold standard is ISTA, 100%, but unless you want to sit with a laptop in your car all the time to change small coding options on the BDU etc, ISTA isnt viable for most. I once went down this route, taught myself the navigation around it and could do it, but it was always a ball-ache for me and more trouble than it was worth.
There is much to be said about the functionality between something like ISTA and Bimmercode, so YMMV, but for most just changing small things and comfort options etc, Bimmercode and the various variants like it sill be best.
Some swear by Carly, others by BimmerCode and then if you want to read every module, control unit and every error code, then ISTA is the one.
From what I can see online the OBDLink CX and Bimmercode seem to be the most reliable choice, although there are many such OBD Bluetooth dongles that work similarly, theyre just not recommended by BimmerCode.
Also, when changing many things make sure the battery is plugged in otherwise you can create module errors from ,losing power when the app/device is writing to the car. Better be safe and plug it in to a charger/make sure there is adequate power to the car.
Razeen
Hi Solo Man. I'm new to this forum and 1st BMW . I have a BMW X3 2020 Sdrive18D. I'm looking to code a different instrument cluster. Mine is pretty standard just changes from Orange to White. No fancy dials. Is it possible we can connect and see if you able to assist me in changing the cluster gauges?
Solo Man
I would happily assist you but have never done coding on such a "new" car. Newest car i did work on was 2016 F30 320d i owned. Coding is not rocket science and i can sit by and give directions but the risk is on you. As i said, will happily assist you. Will pm you my phone number if you want to connect.
Gordvisr
bought the vlinker through takealot works well with bimmercode and bimmerlink.
Teezoh
You need to be more specific here though, as you cannot magically create a completely new instrument cluster UI if the hardware/software variant does not support it.
Razeen
Hi Teezoh, So the cluster I have, what I searched and came up with is a 6WB. Mine only changes the numbers from white to orange. The orange is only at night, It is a fully digital cluster. The metal rings are longer than the ones on the XDRIVE20D models, which changes the whole digital display when selecting sport and eco mode etc. Shaheen has the Alpina look. So, I wanted to know if this clock can be software-updated or changed with BimmerCode to have this display. See the picture for what the clock display looks like.
Razeen
I don't think you have the 6WB cluster.
What happens when you switch it into sport/eco mode?
Damn, here I am thinking because it is fully digital, it is a 6wb
When I change modes, only the lights change from white to Orange at night in comfort mode. White in Eco pro and Sport mode(with M logo in this mode only) in the day it is only White no matter what mode but it pops up with the mode you select on the cluster.
Tried yesterday to code Alpina dials, it did the code, but nothing changed. We could code the digital speed onto the cluster. So that shows with the date and temp. Then, using the stalk, you can cycle through and it gives speed in that menu as well. But the 2 speeds together have a difference of 3 or so km/h. The one is fixed digital speed in the cluster and the other you can cycle through the options and select digital speed if you want.
