200k and counting
getty150
Even with the noticeable small amount of debris attached to the radiator I thought the radiator was performing quite well...
I was wrong!
I can tell a considerable difference in chill with the replacement radiator...(without debris)
The debris was sandwiched between the radiator and condenser....
it pays to drain ,remove the radiator and clean off BOTH sides.
Who knew the unseen sandwiched area would hold all this crap...
mud,leaves,bird wings,hair,hay seeds,sand, dead insects etc.
Sent from my TMRV075G using Tapatalk
getty150
Here's what a hairline crack will get you if left unaddressed...
getty150
please let us know on how these perform on the car, was thinking of them for my e46 arms. some people say it makes ride tighter and harsher but better control.
Well been about a month now. One can see and compare the power flex to the standard wish bone , (control arm) or the bushing...
Much more
beefier
tighter fit caused 3 weeks of steering wheel shakes while driving 80miles per hour. The more I drive the less shakes.
Powerflex are ok... Nothing major tho write home about!
I did have a close call where I had to break very quickly and in doing so, I found myself being able to steer out of a tight collision with the other car . Or maybe be it was my cat like reflexes.
Remember I picked these up from the boneyard.
I'd buy them again only at boneyard prices.
I think the biggest advantage is probably longevity.
I'm glad I got them for sure...
But definitely not looking for a second pair to purchase. If given to me, I wouldnt turn them down. And that's another story!
Sent from my 9029W using Tapatalk
Sibonelo
Well been about a month now. One can see and compare the power flex to the stand wish bone , (control arm) or the bushing...
Much more
beefier
They are ok... Nothing major tho write home about!
I did have a close call where I had to break very quickly and in doing so, I found myself being able to steer out of a tight hit the other car situation. Or maybe be it was my cat like reflexes.
But definitely not looking for a second pair to purchase. If given to me, we'll that's another story!
Thanks man this is a nice write up on them.. lol you a Max Verstapen in hiding!
getty150
I've often said the cold over the heat will expose the cars vulnerabilities.
So it was this evening. After work on my way home one of the two pipes under the intake bursts.
Damn cold out too.
I was able to make it home (8miles). With a couple of stops in putting water in the expansion tank. So I know what I'll be doing over the weekend.
getty150
Well it was a good run there were threats in the past but it's for certain... the roof shade expired today now I'm one of thousands with the non functioning BMW roof$ !
getty150
Well on the same day I replaced one of the two coolent pipes located under the intake...I hear noise grinding coming from below the car passenger side maybe front but could be rear...
After completing the pipe I'm contemplating should I change the Bosch recon starter to a reman aftermarket ? I installed the Bosch maybe 8 years ago.
Sent from my TMAF035G using Tapatalk
getty150
if it gave u 8 Years I rate replace with same? are they pricey?
BMW or Bosch all pricey.
I've got a starter on the shelf. Took both to the specialty shop guy says the one just off the car has life left but, the one off my shelf is ready to go,
I told him my dilemma...shop owner says like you,
switch'em out!
Install the one right off the shelf!
Uninstalled the crank sensor, cleaned it off... would have changed it out but I can't find the replacements.
*Any other brand other than OEM...your taking a major chance this is a job you only want to do...never!
getty150
Car now cranks holds,,,then dies.
What did I do...?
Changed:
*coolant pipe
*starter
*crank position sensor
*refreshed coolant system
So she sits for a couple weeks now until I have time to research and take repairing action
Now 5 days later and the fix was....
the damn MAF sensor and the icv!
And I was so sure it was the fuel pump...
Now for the test drive...
*Engine stalls and dies, Gone
*Engine Idel searching , Gone
*EML light and codes, Gone
X is back to being a carpet ride
Sent from my SM-A146U using Tapatalk
getty150
I've grown tired of the original X3 Net pockets, clever but,,,,the 08 door cards with hard sided pockets fit perfectly just as well.
04 to 10 is the same car basically except for the engine M54 N52.
