Hi All,
So I have experience this this issue for a few months now.
The initial Diagnostics pointed to bad Coil Packs 1&2. I replace all 6 with OEM Coilpacks. 2 days later the misfire was back. Did another Diagnostics and this time it pointed to Post Cat Sensor in active. Replaced this sensor and the problem was still there but this time diagnostics pointed to Bank 1 Sensor 2. Replace that and 2 days later it started the misfire again. Did another Diagnostics and this time the fault was Fuelsys1 02Sensor OL. I started by cleaning the DME. Then the fault was only in the mornings. Please can I get an insight into this issue.
