FISAACS
I paid $290 in April for my e46 head unit. The e39 unit would be similarly priced. Including shipping but excluding import charges I paid $365.how much do these go for. need it for my e39
Good choice man, looks very classy.Fitted this Dynavin head unit in the M5, I wanted the “OEM” look but with Apple Car play
Works great
thanks man.. how much was the import dutiesI paid $290 in April for my e46 head unit. The e39 unit would be similarly priced. Including shipping but excluding import charges I paid $365.
Don't remember bro, I'll check my bank statement. The duties are calculated on the "declared" amount.thanks man.. how much was the import duties
That is the best, if not only way, to do thingsOn to other things.
As the S62 engine parts are starting to list as NLA or DELETED I decided to strip and re do the motor.
Cylinder heads off to engineering and then bearings mains and big ends.
Although the S62 is very gentle on the mains the big ends suffer and given that the donor said 170K kms and looked like 500K kms I think it is best to do everything.
How dare you doubt the odometer.That is quite varnishy for a 170k motor...
Most likely true mileage then.How dare you doubt the odometer.
More like 300K kms is my guess although big ends look good and the bores are unmarked
maybe they'll use CSL discsthis is going to be a dope dope car. Will be interesting to see the 135 calipers compared to stock. I imagine the OEM discs will also probably be cheaper than M5 ones. Those ripped me a new hole when I replaced themma
CSL and M5 discs are very close in price.maybe they'll use CSL discs
