Mr Krabs
Hey everyone,
I trust you're well. Is my BMW E90 N46 320i far too gone and not worth it to repair?
Car is in limp mode. Took to BMW, they quoted to replace valve stem seals and eccentric shaft sensor. Now they notice cylinder 2 fails compression test and has a 45% leak on the leakage test. They recommend me having the cylinder block removed and sent away for a deep clean and lapping and cleaning valves and changing the stem seals with the head off.
The milage is at 226 678km, and they said there is a great chance the engineers would advise BMW and I of it being on the limit of spec. That it either needs a new engine or be re-assembled at my own risk. BMW said the cost of the sending it to the engineers would be twice as much as just having the valve stem seals replaced. Est maybe R80 000, while just the valve stem seals at R40 000.
What's everyone's opinion? The past year or two. I did a transmission service at ZF, new propshaft, new battery, new starter, new VANOS motor and some other things.
Should I just cut my loses and sell the car on? The car body is in really good shape.
I had pictures taken of the carbon build up in cylinder 2 and my compression tests.
