Post Reply
Thread Rating:
  • 0 Vote(s) - 0 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Battery drain on 335 when boot opened
17-02-2017, 07:03 AM
Post: #1
Hi Guys
Need your expert advice, my 2010 e92 335i msport dct battery is drained flat when opening the boot even for a short period. I have had the battery tested and it is in perfect health, the car starts after being left standing for over 24 hours but if the boot is opened the ignition lights dont come on. I have removed the boot light but it hasn't fixed the issue. Some guy advised that it could be the boot switch which is faulty can anyone confirm this and where could I get one and how much it costs, plus how would I go about changing it. even a good auto electrician in the south of Johannesburg that I could use to diagnose the problem would be much appreciated.
thank you guys in advance
Find all posts by this user
17-02-2017, 08:35 AM
Post: #2
RE: Battery drain on 335 when boot opened
Thats strange bro
AKASH
Masstronix E90 335i AT Sportpack (JB4, DP, DCI. Race flash 265wkw @622NM at KAR)
E90 323i Sportpack
17-02-2017, 10:24 AM
Post: #3
If u suspect the boot lock then i would disconnect it and test before buying a new one
17-02-2017, 11:28 AM (This post was last modified: 17-02-2017 11:29 AM by Thaves.)
Post: #4
(17-02-2017 08:35 AM)akash Wrote:  Thats strange bro
Yeah it is as i cant seem to find any information anywhere on this specific issue
(17-02-2017 10:24 AM)DannyBoyOPC Wrote:  If u suspect the boot lock then i would disconnect it and test before buying a new one
thanks for the response, how would i go about doing that on the fuse box or directly on the lock?
17-02-2017, 04:44 PM
Post: #5
If you find a fuse for it then pull the fuse. I have never removed one from a BMW but mu guess is under the carpet on the boot lid is where you will find the motor
Post Reply
User(s) browsing this thread:
1 Guest(s)
